best resolution for tv
oilisab
Post by oilisab »
What is teh best resolution and codec to
watch a "mostly images" video on a tv using a dvd player??
THoff
Post by THoff »
Unless you have one of the few DVD players that supports DIVX, MPEG4, or JPEG file viewing, you have only one choice: MPEG2 at the Full D1 resolution used by the TV standard in your country (PAL or NTSC).
Make sure you check the "Apply anti-flicker filter" checkbox, and possibly apply a slight Gaussian Blur to the images. You may also want to use frame-based MPEG2 instead of interlaced MPEG2.
jbowen28
Post by jbowen28 »
"You may want to use frame based MPEG2" but if you have an interlaced TV, as most of us do, it is bad news.
jbowen28
Post by jbowen28 »
jbowen28
Post by jbowen28 »
THoff
Post by THoff »
frame-based MPEG2 is not a bad idea, especially when most of the assets are still images, as the original poster intends to use. Frame-based output will eliminate flicker and color roll, and the fact that most TVs are interlaced has no bearing on this.
