I just downloaded and installed video studio 9 trial.
I have plenty of hard disk space and a fast computer.
I captured video in AVI format.
I render in Mpeg2 format according to the recommended settings.
At the end of the rendering VS 9 crashes.
The video is avialable to be burned onto a DVD but if I try to watch it through windows media player it crashes. I also cannot watch it through videostudio.
Any suggestions?
ulead video studio 9
maddrummer3301
The mpg2 file is corrupt and probably has to be deleted and recreated
again.
What format did you use to create the .AVI file
If DV format Type2 then change the format to Type 1.
You can re-render the avi file to Type1 or download the utility as the ulead
website to change the file from Type2 to Type1.
MD
again.
MD
howied
howied
Ok did some more experimenting.
When I select
Create video file
I am able to render the video and view it with media player in:
NTSC DV mode
NTSC MPEG 2 mode
When I render from
NTSC DVD mode
I cannot view with media player.
When I render with video player 8 in NTSC DVD mode... I can also view with media player
How can this be a file curruption issue.
My trial ends in 6 days ... any help or alas shall I stick with videostudio 8.
Is there a difference between rendering in MPEG 2 mode and DVD mode with regards to burning on DVD. I was always told to render in the right mode first before burning.
When I select
Create video file
NTSC DV mode
NTSC MPEG 2 mode
When I render from
NTSC DVD mode
heinz-oz
There are ample happy users of VS9 out there. I do not have VS and therefore do not know if there was an issue with it on some machines which have been fixed with a patch. As patches do not work with trial versions, I'm afraid, you can't check that out.
I guess you have 2 options, stick your neck out and get the update version of VS 9 (since you have VS 8 ) or stick with what you have got.
Without being able to check it out, I'm still confident that all that's wrong with your project settings, is something simple, like incompatible sound options, frame size or such. I'm in PAL land, but NTSC, I think, cannot handle mpg sound. Does your project settings specify LPCM for sound or mpg? Also, if I'm not mistaken, VS 8 does not have AC3 support, maybe that's why it works with VS 8 but not with VS 9.
Check it out
Check it out
maddrummer3301
howied
heinz-oz wrote:There are ample happy users of VS9 out there. I do not have VS and therefore do not know if there was an issue with it on some machines which have been fixed with a patch. As patches do not work with trial versions, I'm afraid, you can't check that out.
Check it out
Ok now have full version.
still having problems
If I render with lpcm audio
media player crashed when I try to view MPEG.
If I render with Mpeg audio, mpeg plays on media player
However....
If I render with Mpeg audio and then burn to my DVD.... I sometimes don't hear any sound on my standalone DVD player. I do hear sound when played through the computer dvd.
Is media player not able to play mpegs encoded with LPCM audio?
Do Stand alone DVD's not have the ability to play MPEG audio?
Why didn't I have this problem with videostudio 8.
Help!!!
maddrummer3301
Many older NTSC players do not play Mpeg audio.
Almost all the newer NTSC dvd players can now play mpeg audio.
Maybe your dvd player is an older unit. Usually if the dvd player can play
VCD's then it can also play mpeg audio on DVD's.
Why don't you try Dolby Audio when you export the video to mpeg2.
That should definitely play in the dvd player.
You said Windows Media Player crashed before and is still crashing.
Do you have any other dvd playing software on the computer such as
"Power DVD or Windvd"?
Installing or re-installing one of the above players may correct the codec
issue your having with the windows media player.
Also make sure to be running the latest version of DirectX.
Hope this helps,
MD
Hope this helps,
MD
jchunter
Howard,
I suspect that you are not setting your "properties" correctly when you create your video file.
You said:
"I am able to render the video and view it with media player in:
NTSC DV mode
NTSC MPEG 2 mode"
These "modes" are not properties, they are merely templates that contain sets of properties that may or may not be appropriate for your project.
Always set properties when Creating Video by selecting "Custom" and then "Options" to get to the detailed property list. Ditto when you Create Disk.
John
NTSC DV mode
NTSC MPEG 2 mode"
John
