Windows XP File Size
dshaf
Post by dshaf »
I'm running VideoStudio 7.0 SE on Windows XP Professional with an NTFS file system. The support files say there are no restrictions to file sizes (as the 4GB with a Fat32) when capturing. I still seem to have a 4GB restriction and it keeps starting new 4GB files during long captures.
Any ideas?
I also have a video problem during long captures. After a long period of capturing the video starts to become inverted. What's up with that?
jday
Post by jday »
Please excuse me if I'm asking the obvious, but are you sure that your file structure is NTFS and not FAT32. WindowsXP drives can use either one and most new computers with XP (in my experience) come with the FAT32 file structure and the user needs to convert it.
I only ask because your drive is acting like a FAT32 drive by not allowing a file larger than 4GB.
THoff
Post by THoff »
Some codecs also have their own restrictions, so even though XP and UVS can handle files > 4GB, the codec that compresses the video/audio inside the files you are creating may not be able to handle it.
rwindeyer
Post by rwindeyer »
I had a simliar issue recently; during a long (4 hour) capture, the incoming video was broken into 4 Gb chunks. So I had half a dozen or so clips in the library.
After minimal editing, there was no problem whatever with creating a 25 Gb avi video file. (I have XP SP2 and NTFS file system).
This may be a VS feature rather than a NTFS/XP restriction.
dshaf
file sys
Post by dshaf »
I agree, rwindeyer.
I know that there are no file size limitations in an NTFS file system (as I'm a Microsoft Certified Professional). It sure seems like the VS software may be to blame. Guess I'll have to check with Ulead on that.
Putting the clips together afterwards seems too tedious. My last project was a concert from TV.
Any one else have any ideas on the inverted video problem I got when capturing long clips?
dshaf
codecs
Post by dshaf »
THoff wrote:Some codecs also have their own restrictions, so even though XP and UVS can handle files > 4GB, the codec that compresses the video/audio inside the files you are creating may not be able to handle it.
Wonder if the codec(s) could also cause my inverted video problem?
I'll check it out.
THoff
Post by THoff »
dshaf, take a look at THIS Microsoft Knowledgebase entry. While this refers to Windows Media Encoder, the problem is actually with the codec that created the file that plays upside down.
Barry
4 gig limit
Post by Barry »
dshaf,
Load the patch for VS7 and the 4 gig limit will go away.
Look part way down this page http://www.ulead.com/tech/vs/vs_ftp70.htm
All the best
Barry
dshaf
Post by dshaf »
THoff wrote:dshaf, take a look at THIS Microsoft Knowledgebase entry. While this refers to Windows Media Encoder, the problem is actually with the codec that created the file that plays upside down.
My video problem is not upside down. I mean that it looks like a picture negative. Maybe caused by the same thing?
I'll keep that KB article around just in case.
Thanx
dshaf
Post by dshaf »
Thanks Barry
I'll install the patch.
I saw the patch on the Ulead web site, but didn't think it was necassary for WinXP.
Barry
4gig file limit VS7 NTFS XP
Post by Barry »
dshaf,
That patch lists the 4gig limit on NTFS as one of the issues it fixes.
And it does fix it, I've tried both with and without the patch.
Barry
