Hello,
I am using an 18% gray card and the Grey Point tool to adjust the colors in my images. I am happy with the results. However, my workflow is to take one photo with the gray card in frame, and then a similar photo without the gray card. I would like to use the corrected color curves from the photo with the gray card--discovered by using the Grey Point tool--and apply them to photo without the gray card. How can I do this?
Using gray point across several images?
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Re: Using gray point across several images?
Copy&Paste, Selective Copy&Paste or via a Copy Set.
cheers
afx
cheers
afx
