I am running Win 7 64bit Pro with several users defined on a PC. PSP X4 runs OK for my user, but all other users cannot start PSP X4 they get a message Temp Directory not defined. The Temp Directory is defined and valid with write permissions.
Windows is installed on C: drive, but User directories are on E: Drive
PSP X4 version 14.3.0.3
I have reviewed a post for a similar issue, but this does not apply for my issue
http://forum.corel.com/EN/viewtopic.php ... ot+defined
I have even tried copying the corel hive of HKCU\Software\Corel from my user and "Documents\Corel Paintshop Pro" directory to the other user, but still get the temp directory is not defined message
So basically although PSP X4 is running for one user on the PC, none of the other users can start it to run for the first time
Any ideas?
Temp Directory not defined when running PSP X4 for 1st time
Simone Corel UK
- Alludo
Re: Temp Directory not defined when running PSP X4 for 1st t
@marcp
Yes, the other users are users and no administrators (I suppose).So basically although PSP X4 is running for one user on the PC, none of the other users can start it to run for the first time
Any ideas?
