AfterShotPro 1.1.0.30 doesn't start *SOLVED*
Bugs & Suggestions
Ferry
operating_system: Linux
System_Drive: N/A
Post by Ferry »
Hello Forum,
at last I run AfterShotPro 1.0.1.10 without problems. After updating to 1.1.0.30 it doesn't start anymore. There are no errrors displayed. It hangs at "**** Making CL Manager".
Code: Select all
user@desktop ~ $  /usr/bin/AfterShotPro
Install Path:           /opt/AfterShotPro
LD_PATH:                /opt/AfterShotPro/lib:
XLIB_SKIP_ARGB_VISUALS: 1
	linux-gate.so.1 =>  (0xf7788000)
	libuuid.so.1 => /opt/AfterShotPro/lib/libuuid.so.1 (0x0070c000)
	libtcmalloc_minimal.so.0 => /opt/AfterShotPro/lib/libtcmalloc_minimal.so.0 (0xf7754000)
	libdl.so.2 => /lib32/libdl.so.2 (0xf772e000)
	libOpenCL.so.1 => /opt/AfterShotPro/lib/libOpenCL.so.1 (0xf7728000)
	libz.so.1 => /usr/lib32/libz.so.1 (0xf7710000)
	libQtWebKit.so.4 => /opt/AfterShotPro/lib/libQtWebKit.so.4 (0xf6532000)
	libQtSvg.so.4 => /opt/AfterShotPro/lib/libQtSvg.so.4 (0xf64db000)
	libQt3Support.so.4 => /opt/AfterShotPro/lib/libQt3Support.so.4 (0xf61e9000)
	libQtSql.so.4 => /opt/AfterShotPro/lib/libQtSql.so.4 (0xf6134000)
	libQtNetwork.so.4 => /opt/AfterShotPro/lib/libQtNetwork.so.4 (0xf602a000)
	libQtDesigner.so.4 => /opt/AfterShotPro/lib/libQtDesigner.so.4 (0xf5a14000)
	libQtXml.so.4 => /opt/AfterShotPro/lib/libQtXml.so.4 (0xf59cf000)
	libQtGui.so.4 => /opt/AfterShotPro/lib/libQtGui.so.4 (0xf4f0c000)
	libQtCore.so.4 => /opt/AfterShotPro/lib/libQtCore.so.4 (0xf4c65000)
	libpthread.so.0 => /lib32/libpthread.so.0 (0xf4c4c000)
	libstdc++.so.6 => /opt/AfterShotPro/lib/libstdc++.so.6 (0x03aca000)
	libm.so.6 => /lib32/libm.so.6 (0xf4c25000)
	libgcc_s.so.1 => /usr/lib32/libgcc_s.so.1 (0xf4c08000)
	libc.so.6 => /lib32/libc.so.6 (0xf4aab000)
	/lib/ld-linux.so.2 (0xf7789000)
	libXrender.so.1 => /usr/lib32/libXrender.so.1 (0xf4aa2000)
	libfontconfig.so.1 => /usr/lib32/libfontconfig.so.1 (0xf4a72000)
	libfreetype.so.6 => /usr/lib32/libfreetype.so.6 (0xf49fa000)
	libXext.so.6 => /usr/lib32/libXext.so.6 (0xf49eb000)
	libX11.so.6 => /usr/lib32/libX11.so.6 (0xf48ce000)
	librt.so.1 => /lib32/librt.so.1 (0xf48c4000)
	libexpat.so.1 => /usr/lib32/libexpat.so.1 (0xf489e000)
	libxcb.so.1 => /usr/lib32/libxcb.so.1 (0xf4885000)
	libXau.so.6 => /usr/lib32/libXau.so.6 (0xf4882000)
	libXdmcp.so.6 => /usr/lib32/libXdmcp.so.6 (0xf487d000)
0.0: I have SSE2
0.9: Bibble program arguments ("./AfterShotPro")
0.10: Loaded  "/opt/AfterShotPro/supportfiles/locale/aftershot_de.qm"
0.10: Loaded  "/opt/AfterShotPro/supportfiles/locale/qt_de.qm"
0.11: Loading plugins
0.14: Initialising  FatToni  filter
0.18: Warning: slow tiles used because plugin is not white listed:  "Nuance"
0.20: Initialising  Wavelet Sharpen 3  filter
0.21: Warning: slow tiles used because plugin is not white listed:  "WaveletSharpen2"
0.21: Warning: slow tiles used because plugin is not white listed:  "zPerspector"
0.26: System locale: de_DE
0.35: Added plugin locale file:  "/home/user/.AfterShotPro/Plugins/FatToni.afplugin/locale/FatToniPlugin_de.qm"
0.35: Added plugin locale file:  "/home/user/.AfterShotPro/Plugins/Wavelet Sharpen3.afplugin/locale/SharpenPlugin_de.qm"
0.35: Added plugin locale file:  "/opt/AfterShotPro/supportfiles/plugins/Equalizer.afplugin/locale/Equalizer_de.qm"
0.35: Added plugin locale file:  "/opt/AfterShotPro/supportfiles/plugins/Nostalgia.afplugin/locale/Nostalgia_de.qm"
0.35: Loaded  "/opt/AfterShotPro/supportfiles/locale/aftershot_de.qm"
0.35: Loaded  "/opt/AfterShotPro/supportfiles/locale/qt_de.qm"
0.35: Loaded  "/home/user/.AfterShotPro/Plugins/FatToni.afplugin/locale/FatToniPlugin_de.qm"
0.35: Loaded  "/home/user/.AfterShotPro/Plugins/Wavelet Sharpen3.afplugin/locale/SharpenPlugin_de.qm"
0.35: Loaded  "/opt/AfterShotPro/supportfiles/plugins/Equalizer.afplugin/locale/Equalizer_de.qm"
0.36: Loaded  "/opt/AfterShotPro/supportfiles/plugins/Nostalgia.afplugin/locale/Nostalgia_de.qm"
0.80: AfterShot vers.: 1.1.0.30
0.80: Built on: "Sa. Okt 20 2012"
0.80: Language: de
0.80: App Path: /opt/AfterShotPro/bin/AfterShotPro
0.80: System Home: ../supportfiles
0.80: User Home: /home/user/.AfterShotPro
0.80: Prefs Home: /home/user/.config/Corel/AfterShot Pro.conf
0.80: Platform:     Linux
0.80: Issue: "Linux Mint Xfce Edition \n \l"
0.80: Kernel: "Linux version 3.2.0-3-amd64 (Debian 3.2.21-3) (debian-kernel@lists.debian.org) (gcc version 4.6.3 (Debian 4.6.3-8) ) #1 SMP Thu Jun 28 09:07:26 UTC 2012"
0.81: Build Mode:   Release
0.81: Product Name: "AfterShot Pro"
0.81: Registered Version
0.81: Initializing
0.82: Cpu Manager init: 4
0.82: ****	Making CLManager
On my System runs a LinuxMint Debian Edition on a 64bit AMD 3870 APU with Radeon 6550HD. OpenCL is enabled.
I think it's an OpenCL-Problem but I don't know how to solve it.
For the Moment I switched back to 1.0.1.10 - it runs pefectly.
Ferry
PS: Sorry for my bad english!
afx
System_Drive: N/A
Video Card: FirePro 4900
Re: AfterShotPro 1.1.0.30 doesn't start
Post by afx »
Check in the ~/.config directory for the Qt or AfterShot properties. There might be an OpenCL toggle.
Set that to off and then try again (I am not at my Linux box, so I can't check for the file myself).
cheers
afx
hpmickey
System_Drive: N/A
processor: dualcore
ram: 3GB
Video Card: nvidia
Monitor/Display Make & Model: LG W2220P
Post by hpmickey »
Hello, try to change the '~/.config/Corel/AfterShot Pro.conf' line
Code: Select all
Preferences\OpenCL\Enabled=true
to
Code: Select all
Preferences\OpenCL\Enabled=false
It seems to work at least on my Fedora 12 installation. Other distros should be similar, I guess.
Michal
Ferry
System_Drive: N/A
Post by Ferry »
Hello,
to change the CONF-File solves the Problem at first. Thank you for help.
I found out, that the "AMD-APP-SDK" (to use OpenCL on Radeon Graphic Cards) in Version 2.8 was the Problem. Now, I've installed the Version 2.7 an all works fine (with OpenCL enabled too).
In the ASP's "Hardware Acceleration Prefences", "Advanced Micro Devices" is shown as Platform now, but I can't set the Checkbox to use it.
A start in a Terminal tells me, that ASP can't find a OpenCL-Device, but I think it's not an ASP Problem, but a Problem between AMD-SDK and my GPU.
So - I think - this Thread can set to "SOLVED"!
Thank you very much!
Ferry
