ASP 1.10.0.30 White Balance Drop Down not working after Clic
Bugs & Suggestions
HeidiBr
ram: 6GM
Hard_Drive_Capacity: 750GB
Post by HeidiBr »
When I am editing JPEG images, and I click the "click white" button, the image gets modified, that is good,
however,
When I click the white balance drop down, nothing drops down and I cannot reset the white balance to "as Shot".
I was able to reset the white balance doing the menu Edit White Balance Reset
However, this did not fixthe drop down box problem, there was still no drop down.
When I went to edit a raw image after the above problem, the white balance drop down did show up and allow me to use all the white balance options.
Returning to the JPEG image, again, I could "click on white" but not return to 'As shot".
I tend to use white balance a lot, especially on quick casual shots, so this might be a reason to go back to the older version.
Heidi :(
Trucks
operating_system: Linux
System_Drive: N/A
motherboard: 64bit
processor: quad
ram: 3GB
Video Card: Nvidia
sound_card: onboard
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: Eizo S2243 W
Re: ASP 1.10.0.30 White Balance Drop Down not working after
Post by Trucks »
It is not possible to edit the WB in .jpg. You only can edit in RAW.
I forgot the technical background, sorry. I`m sure afx can explain.
Regards
Trucks
HeidiBr
ram: 6GM
Post by HeidiBr »
If I can't edit the white balance in JPEG, why does the program let me click white and then make the changes to the image, and then let me reset using the menu?
The problem is that there is a bug. It let's you do one thing one way and not the same thing another. That is a bug.
Now you are making me re-install the old program to prove that it used to work....
Heidi
afx
System_Drive: N/A
Video Card: FirePro 4900
Post by afx »
HeidiBr wrote:When I click the white balance drop down, nothing drops down and I cannot reset the white balance to "as Shot".
Click on the white balance label to reset, just like on any other tool.
True WB is technically not possible on rendered files. The click white is a cludgy color balance.
I wish they would offer a true color balance for rendered files like the one in PWP...
cheers
afx
