AfterShot 1.1.0.30 Will Not Run On My Computer *SOLVED*
toglenn
motherboard: asrock
processor: intel i7
ram: 12GB
Video Card: ATI 4770
sound_card: on board
Hard_Drive_Capacity: 3.9T
Monitor/Display Make & Model: HP2475
Post by toglenn »
I've tried every way I can think of to get the AfterShot Upgrade 1.1.0.30 to run but Windows keeps stopping it and saying there is a problem and will try to find a solution. I had to download VER. 1.0.1.10 to get AfterShot to run again. Now every time I start the program I get the reminder that there is an upgrade available. I'm running Windows 7 Pro 64bit and had no problems with the previous version. I've tried just running the download over the existing version, deleting the existing version before running the upgrade or running the new version on a different drive. In every case Windows stopped it from running and the original version was trashed. I have downloaded the upgrade three times and each time Windows says there is a problem and stops it from running.
I tried to contact Corel about the problem but their Customer Service is not very user friendly and I could not find a way to tell them about the problem. I don't use the program very much as I prefer Capture One Pro 7 and Photoshop but it nice to see the difference between RAW processing programs.
Update 1/8/2013.....After installing a new graphic card that is compliant with OpenCL I was able to install AfterShot upgrade 1.1.0.30. ****** PROBLEM SOLVED ******
afx
operating_system: Linux
System_Drive: N/A
Video Card: FirePro 4900
Re: AfterShot 1.1.0.30 Will Not Run On My Computer
Post by afx »
What are the last statements in the log file?
Do you have an OpenCL capable GPU?
cheers
afx
toglenn
motherboard: asrock
processor: intel i7
ram: 12GB
Post by toglenn »
afx wrote:What are the last statements in the log file?
cheers
No, my GPU is not OpenCL compliant but Corel does not say that is a requirement to run AfterShot. Been thinking of upgrading but there are not that many advantages as of now.
Here's the log data;
afx
Log Name: Application
Source: Application Error
Date: 12/29/2012 4:25:27 PM
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Computer: Dad-PCOffice
Description:
Faulting application name: AfterShotPro.exe, version: 6.0.0.3, time stamp: 0x5081cf86
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Exception code: 0xc0000005
Fault offset: 0x00000000
Faulting process id: 0xd00
Faulting application start time: 0x01cde6242afc19b9
Faulting application path: G:\Program Files (x86)\Corel\Corel AfterShot Pro\build\AfterShotPro.exe
Faulting module path: unknown
Report Id: 68c2df71-5217-11e2-9d7b-0025221fceaf
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Application Error" />
<EventID Qualifiers="0">1000</EventID>
<Level>2</Level>
<Task>100</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2012-12-30T00:25:27.000000000Z" />
<EventRecordID>205479</EventRecordID>
<Channel>Application</Channel>
<Computer>Dad-PCOffice</Computer>
<Security />
</System>
<EventData>
<Data>AfterShotPro.exe</Data>
<Data>6.0.0.3</Data>
<Data>5081cf86</Data>
<Data>unknown</Data>
<Data>0.0.0.0</Data>
<Data>00000000</Data>
<Data>c0000005</Data>
<Data>d00</Data>
<Data>01cde6242afc19b9</Data>
<Data>G:\Program Files (x86)\Corel\Corel AfterShot Pro\build\AfterShotPro.exe</Data>
<Data>68c2df71-5217-11e2-9d7b-0025221fceaf</Data>
</EventData>
</Event>
afx
System_Drive: N/A
Post by afx »
Not the Windows log, the AS log in your AS User directory...
cheers
afx
toglenn
motherboard: asrock
processor: intel i7
ram: 12GB
Post by toglenn »
afx wrote:Not the Windows log, the AS log in your AS User directory...
cheers
afx
Here's the AS Log. I don't know how helpful it will be as I had to delete the complete directory several times because my original AS version was overwritten by tge new version that would not run.
1981.369: Heaps: 6
1981.373: Bibble program arguments ("G:\Program Files (x86)\Corel\Corel AfterShot Pro\build\AfterShotPro.exe")
1981.373: Loaded "G:/Program Files (x86)/Corel/Corel AfterShot Pro/supportfiles/locale/aftershot_en.qm"
1981.373: Loading plugins
1981.377: System locale: en_US
1981.381: Loaded "G:/Program Files (x86)/Corel/Corel AfterShot Pro/supportfiles/locale/aftershot_en.qm"
1981.409: AfterShot vers.: 1.0.1.10
1981.410: Built on: "Sun Apr 1 2012"
1981.411: Language: en
1981.412: App Path: G:/Program Files (x86)/Corel/Corel AfterShot Pro/build/AfterShotPro.exe
1981.412: System Home: G:/Program Files (x86)/Corel/Corel AfterShot Pro/supportfiles
1981.413: User Home: G:/Program Files (x86)/Corel/User Files
1981.414: Prefs Home: \HKEY_CURRENT_USER\Software\Corel\AfterShot Pro
1981.415: Platform: Windows
1981.415: Build Mode: Release
1981.416: Product Name: "AfterShot Pro"
1981.417: Registered Version
1981.419: Initializing
1981.423: Cpu Manager init: 8
1981.424: OS Name: "Microsoft Windows 7 Service Pack 1"
1981.425: OS Version: "6.1 (Build 7601)"
1981.425: System arch: x64
1981.426: RAM: 12286
1981.427: Memory: 3
1981.428: ====================================================
1981.429: Asset: 2147483647 purge
1981.429: ====================================================
1981.430: Heavy Asset: 2147483647 purge
1981.431: ====================================================
1981.432: BImageTile: 1800 purge
1981.432: ====================================================
1981.433: BTiledImage: 2147483647 purge
1981.434: ====================================================
1981.435: RegionImageTile: 3000 purge
1981.436: ====================================================
1981.437: Histogram: 24 purge
1981.438: Histogram: 12 cache (12 min)
1981.438: ====================================================
1981.439: ImageMaster: 600 purge
1981.440: ImageMaster: 300 cache (50 min)
1981.441: ====================================================
1981.442: NContainer: 2147483647 purge
1981.443: ====================================================
1981.444: NoiseEngine: 150 purge
1981.445: NoiseEngine: 75 cache (50 min)
1981.445: ====================================================
1981.446: Path: 2147483647 purge
1981.447: Path: 2147483647 cache (2147483647 min)
1981.448: ====================================================
1981.449: PerfectlyClear: 6 purge
1981.450: PerfectlyClear: 4 cache (4 min)
1981.451: ====================================================
1981.452: PluginData: 9 purge
1981.453: PluginData: 9 cache (8 min)
1981.454: ====================================================
1981.455: RawData: 25165821 purge
1981.456: ====================================================
1981.456: TileStack: 24 purge
1981.457: TileStack: 12 cache (12 min)
1981.458: ====================================================
1981.459: StackTile: 3000 purge
1981.462: ====================================================
1981.463: UncompressedRawData: 9 purge
1981.464: UncompressedRawData: 9 cache (8 min)
1981.465: ====================================================
1981.466: Version: 600 purge
1981.467: Version: 300 cache (50 min)
1981.468: ====================================================
1981.469: Allocate Asset manager
1981.474: Option group - "" - already contains an option with name - "TIFFTAG_AFMODE"
1981.475: Option was not registered.
1981.476: Option group - "" - already contains an option with name - "TIFFTAG_FLASHMODE"
1981.477: Option was not registered.
1981.478: Globals: systemhome G:/Program Files (x86)/Corel/Corel AfterShot Pro/supportfiles
1981.479: Globals: userhome G:/Program Files (x86)/Corel/User Files
1981.481:
==================== Plugins =====================
Name:
Identifier:
Version: 1.0.0
Path:
Name: Black and White
Identifier: com.corel.BlackAndWhite
Version: 1.0.0
Path: <System Home>/plugins/Black and White.afplugin
Identifier: com.corel.equalizer
Version: 1.0.5
Path: <System Home>/plugins/Equalizer.afplugin
Identifier: com.SMP.Nostalgia
Version: 1.0.8
Path: <System Home>/plugins/Nostalgia.afplugin
1981.555: G:/Program Files (x86)/Corel/User Files/bibbledebug
1981.556: Err: 1
1981.559: Creating main window
1981.563: Starting Catalog Manager
1981.564: New Io Asset Mananager
1981.667: DB 0 at version 20
1981.668: Locking catalog: "G:/Program Files (x86)/Corel/User Files/cache"
1981.669: Locking for station: "{0af264f6-7a6b-4111-82d9-2c39bd0c6ff2}"
1981.671: Opening DB "G:/Program Files (x86)/Corel/User Files/cache"
1981.673: DB 1 is already up to date
1981.675: Scheduled Cache Cleaning
1981.681: CacheReducer removed 0 versions due to age older than QDateTime("Sat Dec 15 19:06:56 2012")
1981.682: Starting cache cleanup
1981.685: Finished cache cleanup
1981.686: Locking catalog: "G:/Program Files (x86)/Corel/User Files/AfterShot Pro Catalog 2012"
1981.687: Locking for station: "{0af264f6-7a6b-4111-82d9-2c39bd0c6ff2}"
1981.688: Opening DB "G:/Program Files (x86)/Corel/User Files/AfterShot Pro Catalog 2012"
1981.690: DB 2 is already up to date
1981.763: Starting Asset Manager
1981.765: Starting Memory Manager
1981.832: Trying to set queue hotkey "T" for queue "16-bit TIFF"
1981.834: Trying to set queue hotkey "8" for queue "8-bit TIFF"
1981.835: Trying to set queue hotkey "D" for queue "Download"
1981.836: Trying to set queue hotkey "F" for queue "JPEG Full Size"
1981.837: Trying to set queue hotkey "J" for queue "JPEG Proof"
1981.974: Trying to set copyset shortcut "Ctrl+8" for "Color Correction"
1981.975: Trying to set copyset shortcut "Ctrl+9" for "Exposure"
1981.976: Trying to set copyset shortcut "Ctrl+3" for "GPS Settings"
1981.977: Trying to set copyset shortcut "Ctrl+4" for "IPTC Photographer's Details"
1981.978: Trying to set copyset shortcut "Ctrl+1" for "Metadata and IPTC"
1981.979: Trying to set copyset shortcut "Ctrl+2" for "Metadata, IPTC, and GPS"
1981.981: Registering AfterShot plugin... "BibbleBuiltin"
1981.982: Registering AfterShot plugin... "Equalizer"
1981.983: Registering AfterShot plugin... "Nostalgia"
1981.984: Registering AfterShot plugin... "BlackAndWhite"
1981.985: 0 : "UncompressedRawData"
1981.986: 1 : "RawNoise"
1981.988: 2 : "Demosaic"
1981.989: 3 : "TiffSrc"
1981.990: 4 : "JpegSrc"
1981.991: 5 : "Mip"
1981.992: 6 : "PreScalingFilter"
1981.993: 7 : "CameraRgbToWorkingspace_Rendered"
1981.994: 8 : "CloneLayer"
1981.995: 9 : "HealRendererFilter"
1981.996: 10 : "Highlights"
1981.997: 11 : "NoiseNinja"
1981.998: 12 : "SpatialDistortion"
1981.999: 13 : "Positive Vignette"
1982.0: 14 : "Mirror"
1982.1: 15 : "Crop"
1982.2: 16 : "WhiteBalance"
1982.3: 17 : "AutoLevel"
1982.4: 18 : "Exposure"
1982.5: 19 : "FillLight"
1982.6: 20 : "CameraRgbToWorkingspace_Raw"
1982.7: 21 : "Sharpen"
1982.8: 22 : "Invert"
1982.9: 23 : "PerfectlyClear"
1982.10: 24 : "Color"
1982.11: 25 : "SelectiveColor"
1982.12: 26 : "EqualizerFilter"
1982.13: 27 : "RgbToLab"
1982.14: 28 : "LabToRgb"
1982.15: 29 : "NostalgiaFilter"
1982.16: 30 : "BlackAndWhiteFilter"
1982.17: 31 : "Curves"
1982.18: 32 : "Negative Vignette"
1982.19: 0 : "VersionStackSrc"
1982.21: 1 : "PostImage"
1982.22: 0 : "JpegSrc"
1982.23: 1 : "Mip"
1982.952: Ready
1983.195: "I" removable
1983.196: "J" removable
1983.197: "K" removable
1983.198: "L" removable
1983.209: Initializing file system view...
1983.230: File system view initialized.
1983.232: Container __CATALOG_ROOT__/assets
1983.263: File does not exist or could not be opened: "G:/Program Files (x86)/Corel/User Files/slideshow.xmp"
1983.265: No custom slideshow settings found
1983.600: No custom shortcuts found at G:/Program Files (x86)/Corel/User Files/hotkeys.xml
1983.740: MultiImageView::doCursor() Invalid cursor mode
1983.817: ContainerAsset could not get path by ID
1983.820: Container __CATALOG_ROOT__/assets
1983.823: Container __CATALOG_ROOT__/assets/F
1983.825: Container __CATALOG_ROOT__/assets/F/Digital Pictures
1983.829: Container __CATALOG_ROOT__/assets/F/Digital Pictures/2012
1983.831: set sort order ascending
1983.832: Container __CATALOG_ROOT__/assets/F/Digital Pictures/2012/12
1983.841: Opening DB "G:/Program Files (x86)/Corel/User Files/cache"
1983.919: viewmode: 1
1984.138: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1170.CR2"
1984.148: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1170.CR2"
1984.151: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1171.CR2"
1984.160: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1171.CR2"
1984.163: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1172.CR2"
1984.174: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1173.CR2"
1984.175: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1172.CR2"
1984.186: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1174.CR2"
1984.187: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1173.CR2"
1984.196: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1174.CR2"
1984.259: Starting import with settings : "<x:xmpmeta xmlns:x="adobe:ns:meta/" x:xmptk="XMP Core 4.4.0">
<rdf:RDF xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#">
<rdf:Description rdf:about=""
xmlns:bibp="http://www.bibblelabs.com/BibblePrivate/5.0/"
bibp:MoveCopy="2"
bibp:LibraryLoc=""
bibp:LibraryID="1042"
bibp:LibraryUuid="{cb982044-b3d5-43d1-aacc-8577fcb57184}"
bibp:Organize="0"
bibp:FolderTemplate=""
bibp:Recurse="false"
bibp:RenameOn="false"
bibp:FileTemplate=""
bibp:ImportPath="F:/Digital Pictures/2012/12"
bibp:KeywordList=""
bibp:FolderFilter=""
bibp:QueueName=""
bibp:QueueType="0"
bibp:QueueOnlyNewFiles="false"
bibp:JobName=""
bibp:PresetList=""/>
</rdf:RDF>
</x:xmpmeta>
1984.278: Adding master versions
1984.435: Adding master versions
1984.437: Scanning file "F:/Digital Pictures/2012/12/5D-0695.CR2"
1984.443: Scanning file "F:/Digital Pictures/2012/12/5D-0696.CR2"
1984.445: Scanning file "F:/Digital Pictures/2012/12/5D-0697.CR2"
1984.448: Scanning file "F:/Digital Pictures/2012/12/5D-0698.CR2"
1984.450: Scanning file "F:/Digital Pictures/2012/12/5D-0699.CR2"
1984.453: Scanning file "F:/Digital Pictures/2012/12/5D-0700.CR2"
1984.455: Scanning file "F:/Digital Pictures/2012/12/5D-0701.CR2"
1984.458: Scanning file "F:/Digital Pictures/2012/12/5D-0702.CR2"
1984.460: Scanning file "F:/Digital Pictures/2012/12/5D-0703.CR2"
1984.462: Scanning file "F:/Digital Pictures/2012/12/5D-0704.CR2"
1984.472: Adding master versions
1984.479: Scanning file "F:/Digital Pictures/2012/12/5D-0705.CR2"
1984.486: Scanning file "F:/Digital Pictures/2012/12/5D-0706.CR2"
1984.488: Scanning file "F:/Digital Pictures/2012/12/5D-0707.CR2"
1984.491: Scanning file "F:/Digital Pictures/2012/12/5D-0708.CR2"
1984.493: Scanning file "F:/Digital Pictures/2012/12/5D-0709.CR2"
1984.496: Scanning file "F:/Digital Pictures/2012/12/5D-0710.CR2"
1984.498: Scanning file "F:/Digital Pictures/2012/12/5D-0711.CR2"
1984.501: Scanning file "F:/Digital Pictures/2012/12/5D-0712.CR2"
1984.505: Scanning file "F:/Digital Pictures/2012/12/5D-0713.CR2"
1984.508: Scanning file "F:/Digital Pictures/2012/12/5D-0714.CR2"
1984.518: Adding master versions
1984.520: Scanning file "F:/Digital Pictures/2012/12/5D-0715.CR2"
1984.527: Scanning file "F:/Digital Pictures/2012/12/5D-0716.CR2"
1984.530: Scanning file "F:/Digital Pictures/2012/12/5D-0717.CR2"
1984.534: Scanning file "F:/Digital Pictures/2012/12/5D-0718.CR2"
1984.537: Scanning file "F:/Digital Pictures/2012/12/5D-0719.CR2"
1984.540: Scanning file "F:/Digital Pictures/2012/12/5D-0720.CR2"
1984.543: Scanning file "F:/Digital Pictures/2012/12/5D-0721.CR2"
1984.546: Scanning file "F:/Digital Pictures/2012/12/5D-0741.CR2"
1984.548: Scanning file "F:/Digital Pictures/2012/12/5D-0742.CR2"
1984.551: Scanning file "F:/Digital Pictures/2012/12/5D-0743.CR2"
1984.560: Adding master versions
1984.562: Scanning file "F:/Digital Pictures/2012/12/5D-1281.TIF"
1984.569: Scanning file "F:/Digital Pictures/2012/12/G1-1152.CR2"
1984.571: Scanning file "F:/Digital Pictures/2012/12/G1-1154.CR2"
1984.573: Scanning file "F:/Digital Pictures/2012/12/G1-1155.CR2"
1984.575: Scanning file "F:/Digital Pictures/2012/12/G1-1156.CR2"
1984.577: Scanning file "F:/Digital Pictures/2012/12/G1-1157.CR2"
1984.579: Scanning file "F:/Digital Pictures/2012/12/G1-1158.CR2"
1984.581: Scanning file "F:/Digital Pictures/2012/12/G1-1165.CR2"
1984.583: Scanning file "F:/Digital Pictures/2012/12/G1-1166.CR2"
1984.585: Scanning file "F:/Digital Pictures/2012/12/G1-1170.CR2"
1984.593: Adding master versions
1984.594: Scanning file "F:/Digital Pictures/2012/12/G1-1171.CR2"
1984.600: Scanning file "F:/Digital Pictures/2012/12/G1-1172.CR2"
1984.603: Scanning file "F:/Digital Pictures/2012/12/G1-1173.CR2"
1984.605: Scanning file "F:/Digital Pictures/2012/12/G1-1174.CR2"
1984.607: Scanning file "F:/Digital Pictures/2012/12/G1-1175.CR2"
1984.609: Scanning file "F:/Digital Pictures/2012/12/G1-1176.CR2"
1984.611: Scanning file "F:/Digital Pictures/2012/12/G1-1177.CR2"
1984.613: Scanning file "F:/Digital Pictures/2012/12/G1-1178.CR2"
1984.616: Scanning file "F:/Digital Pictures/2012/12/G1-1179.CR2"
1984.617: Scanning file "F:/Digital Pictures/2012/12/G1-1180.CR2"
1984.626: Adding master versions
1984.628: Scanning file "F:/Digital Pictures/2012/12/G1-1181.CR2"
1984.633: Scanning file "F:/Digital Pictures/2012/12/G1-1182.CR2"
1984.636: Scanning file "F:/Digital Pictures/2012/12/G1-1183.CR2"
1984.638: Scanning file "F:/Digital Pictures/2012/12/G1-1184.CR2"
1984.640: Scanning file "F:/Digital Pictures/2012/12/G1-1185.CR2"
1984.642: Scanning file "F:/Digital Pictures/2012/12/G1-1186.CR2"
1984.644: Scanning file "F:/Digital Pictures/2012/12/G1-1187.CR2"
1984.646: Scanning file "F:/Digital Pictures/2012/12/G1-1188.CR2"
1984.648: Scanning file "F:/Digital Pictures/2012/12/G1-1189.CR2"
1984.651: Scanning file "F:/Digital Pictures/2012/12/G1-1190.CR2"
1984.660: Adding master versions
1984.661: Scanning file "F:/Digital Pictures/2012/12/G1-1191.CR2"
1984.667: Scanning file "F:/Digital Pictures/2012/12/G1-1192.CR2"
1984.669: Scanning file "F:/Digital Pictures/2012/12/G1-1193.CR2"
1984.671: Scanning file "F:/Digital Pictures/2012/12/G1-1194.CR2"
1984.672: Scanning file "F:/Digital Pictures/2012/12/G1-1195.CR2"
1984.674: Scanning file "F:/Digital Pictures/2012/12/G1-1196.CR2"
1984.676: Scanning file "F:/Digital Pictures/2012/12/G1-1197.CR2"
1984.678: Scanning file "F:/Digital Pictures/2012/12/G1-1198.CR2"
1984.680: Scanning file "F:/Digital Pictures/2012/12/G1-1200.CR2"
1984.682: Scanning file "F:/Digital Pictures/2012/12/G1-1201.CR2"
1984.688: Adding master versions
1984.689: Scanning file "F:/Digital Pictures/2012/12/G1-1202.CR2"
1984.694: Scanning file "F:/Digital Pictures/2012/12/G1-1203.CR2"
1984.696: Scanning file "F:/Digital Pictures/2012/12/G1-1204.CR2"
1984.698: Scanning file "F:/Digital Pictures/2012/12/G1-1205.CR2"
1984.699: Scanning file "F:/Digital Pictures/2012/12/G1-1206.CR2"
1984.701: Scanning file "F:/Digital Pictures/2012/12/G1-1207.CR2"
1984.703: Scanning file "F:/Digital Pictures/2012/12/G1-1208.CR2"
1984.705: Scanning file "F:/Digital Pictures/2012/12/G1-1209.CR2"
1984.707: Scanning file "F:/Digital Pictures/2012/12/G1-1210.CR2"
1984.709: Scanning file "F:/Digital Pictures/2012/12/G1-1211.CR2"
1984.715: Adding master versions
1984.717: Scanning file "F:/Digital Pictures/2012/12/G1-1212.CR2"
1984.721: Scanning file "F:/Digital Pictures/2012/12/G1-1213.CR2"
1984.724: Scanning file "F:/Digital Pictures/2012/12/G1-1214.CR2"
1984.725: Scanning file "F:/Digital Pictures/2012/12/G1-1215.CR2"
1984.727: Scanning file "F:/Digital Pictures/2012/12/G1-1216.CR2"
1984.729: Scanning file "F:/Digital Pictures/2012/12/G1-1217.CR2"
1984.731: Scanning file "F:/Digital Pictures/2012/12/G1-1218.CR2"
1984.733: Scanning file "F:/Digital Pictures/2012/12/G1-1219.CR2"
1984.735: Scanning file "F:/Digital Pictures/2012/12/G1-1220.CR2"
1984.736: Scanning file "F:/Digital Pictures/2012/12/G1-1221.CR2"
1984.743: Adding master versions
1984.744: Scanning file "F:/Digital Pictures/2012/12/G1-1222.CR2"
1984.749: Scanning file "F:/Digital Pictures/2012/12/G1-1223.CR2"
1984.751: Scanning file "F:/Digital Pictures/2012/12/G1-1224.CR2"
1984.752: Scanning file "F:/Digital Pictures/2012/12/G1-1225.CR2"
1984.754: Scanning file "F:/Digital Pictures/2012/12/G1-1226.CR2"
1984.756: Scanning file "F:/Digital Pictures/2012/12/G1-1227.CR2"
1984.758: Scanning file "F:/Digital Pictures/2012/12/G1-1228.CR2"
1984.760: Scanning file "F:/Digital Pictures/2012/12/G1-1229.CR2"
1984.762: Scanning file "F:/Digital Pictures/2012/12/G1-1230.CR2"
1984.763: Scanning file "F:/Digital Pictures/2012/12/G1-1231.CR2"
1984.770: Adding master versions
1984.771: Scanning file "F:/Digital Pictures/2012/12/G1-1232.CR2"
1984.775: Scanning file "F:/Digital Pictures/2012/12/G1-1233.CR2"
1984.777: Scanning file "F:/Digital Pictures/2012/12/G1-1234.CR2"
1984.779: Scanning file "F:/Digital Pictures/2012/12/G1-1235.CR2"
1984.781: Scanning file "F:/Digital Pictures/2012/12/G1-1236.CR2"
1984.783: Scanning file "F:/Digital Pictures/2012/12/G1-1237.CR2"
1984.785: Scanning file "F:/Digital Pictures/2012/12/G1-1238.CR2"
1984.786: Scanning file "F:/Digital Pictures/2012/12/G1-1239.CR2"
1984.788: Scanning file "F:/Digital Pictures/2012/12/G1-1240.CR2"
1984.790: Scanning file "F:/Digital Pictures/2012/12/G1-1241.CR2"
1984.796: Adding master versions
1984.798: Scanning file "F:/Digital Pictures/2012/12/G1-1242.CR2"
1984.802: Scanning file "F:/Digital Pictures/2012/12/G1-1243.CR2"
1984.804: Scanning file "F:/Digital Pictures/2012/12/G1-1244.CR2"
1984.806: Scanning file "F:/Digital Pictures/2012/12/G1-1245.CR2"
1984.808: Scanning file "F:/Digital Pictures/2012/12/G1-1246.CR2"
1984.810: Scanning file "F:/Digital Pictures/2012/12/G1-1247.CR2"
1984.811: Scanning file "F:/Digital Pictures/2012/12/G1-1248.CR2"
1984.813: Scanning file "F:/Digital Pictures/2012/12/G1-1249.CR2"
1984.815: Scanning file "F:/Digital Pictures/2012/12/G1-1250.CR2"
1984.817: Scanning file "F:/Digital Pictures/2012/12/G1-1251.CR2"
1984.824: Adding master versions
1984.825: Scanning file "F:/Digital Pictures/2012/12/G1-1252.CR2"
1984.830: Scanning file "F:/Digital Pictures/2012/12/G1-1253.CR2"
1984.832: Scanning file "F:/Digital Pictures/2012/12/G1-1254.CR2"
1984.833: Scanning file "F:/Digital Pictures/2012/12/G1-1255.CR2"
1984.835: Scanning file "F:/Digital Pictures/2012/12/G1-1256.CR2"
1984.837: Scanning file "F:/Digital Pictures/2012/12/G1-1257.CR2"
1984.839: Scanning file "F:/Digital Pictures/2012/12/G1-1258.CR2"
1984.841: Scanning file "F:/Digital Pictures/2012/12/G1-1259.CR2"
1984.843: Scanning file "F:/Digital Pictures/2012/12/G1-1260.CR2"
1984.844: Scanning file "F:/Digital Pictures/2012/12/G1-1261.CR2"
1984.851: Adding master versions
1984.852: Scanning file "F:/Digital Pictures/2012/12/G1-1262.CR2"
1984.857: Scanning file "F:/Digital Pictures/2012/12/G1-1263.CR2"
1984.858: Scanning file "F:/Digital Pictures/2012/12/G1-1264.CR2"
1984.860: Scanning file "F:/Digital Pictures/2012/12/G1-1265.CR2"
1984.862: Scanning file "F:/Digital Pictures/2012/12/G1-1266.CR2"
1984.864: Scanning file "F:/Digital Pictures/2012/12/G1-1268.CR2"
1984.866: Scanning file "F:/Digital Pictures/2012/12/G1-1269.CR2"
1984.867: Scanning file "F:/Digital Pictures/2012/12/G1-1270.CR2"
1984.869: Scanning file "F:/Digital Pictures/2012/12/G1-1271.CR2"
1984.871: Scanning file "F:/Digital Pictures/2012/12/G1-1272.CR2"
1984.877: Adding master versions
1984.879: Scanning file "F:/Digital Pictures/2012/12/G1-1273.CR2"
1984.883: Scanning file "F:/Digital Pictures/2012/12/G1-1274.CR2"
1984.885: Scanning file "F:/Digital Pictures/2012/12/G1-1275.CR2"
1984.887: Scanning file "F:/Digital Pictures/2012/12/G1-1276.CR2"
1984.889: Scanning file "F:/Digital Pictures/2012/12/G1-1277.CR2"
1984.891: Scanning file "F:/Digital Pictures/2012/12/G1-1278.CR2"
1984.892: Scanning file "F:/Digital Pictures/2012/12/G1-1279.CR2"
1984.894: Scanning file "F:/Digital Pictures/2012/12/G1-1280.CR2"
1984.896: Scanning file "F:/Digital Pictures/2012/12/G1-1282.CR2"
1984.898: Scanning file "F:/Digital Pictures/2012/12/G1-1283.CR2"
1984.904: Adding master versions
1984.906: Scanning file "F:/Digital Pictures/2012/12/G1-1284.CR2"
1984.910: Scanning file "F:/Digital Pictures/2012/12/G1-1285.CR2"
1984.912: Scanning file "F:/Digital Pictures/2012/12/G1-1286.CR2"
1984.914: Scanning file "F:/Digital Pictures/2012/12/G1-1287.CR2"
1984.916: Scanning file "F:/Digital Pictures/2012/12/G1-1288.CR2"
1984.918: Scanning file "F:/Digital Pictures/2012/12/G1-1289.CR2"
1984.920: Scanning file "F:/Digital Pictures/2012/12/G1-1291.CR2"
1984.921: Scanning file "F:/Digital Pictures/2012/12/G1-1292.CR2"
1984.923: Scanning file "F:/Digital Pictures/2012/12/G1-1293.CR2"
1984.925: Scanning file "F:/Digital Pictures/2012/12/G1-1294.CR2"
1984.932: Adding master versions
1984.933: Scanning file "F:/Digital Pictures/2012/12/G1-1295.CR2"
1984.938: Scanning file "F:/Digital Pictures/2012/12/G1-1296.CR2"
1984.940: Scanning file "F:/Digital Pictures/2012/12/G1-1300.CR2"
1984.941: Scanning file "F:/Digital Pictures/2012/12/G1-1301.CR2"
1984.943: Scanning file "F:/Digital Pictures/2012/12/LX3-20504.RW2"
1984.945: Scanning file "F:/Digital Pictures/2012/12/LX3-20505.RW2"
1984.947: Scanning file "F:/Digital Pictures/2012/12/LX3-20506.RW2"
1984.949: Scanning file "F:/Digital Pictures/2012/12/LX3-20507.RW2"
1984.951: Scanning file "F:/Digital Pictures/2012/12/LX3-20508.RW2"
1984.952: Scanning file "F:/Digital Pictures/2012/12/LX3-20509.RW2"
1984.959: Adding master versions
1984.960: Scanning file "F:/Digital Pictures/2012/12/LX3-20510.RW2"
1984.965: Scanning file "F:/Digital Pictures/2012/12/LX3-20511.RW2"
1984.967: Scanning file "F:/Digital Pictures/2012/12/LX3-20512.RW2"
1984.969: Scanning file "F:/Digital Pictures/2012/12/LX3-20513.RW2"
1984.971: Scanning file "F:/Digital Pictures/2012/12/LX3-20514.RW2"
1984.972: Scanning file "F:/Digital Pictures/2012/12/LX3-20515.RW2"
1984.974: Scanning file "F:/Digital Pictures/2012/12/LX3-20516.RW2"
1984.977: Scanning file "F:/Digital Pictures/2012/12/LX3-20517.RW2"
1984.978: Scanning file "F:/Digital Pictures/2012/12/LX3-20518.RW2"
1984.980: Scanning file "F:/Digital Pictures/2012/12/LX3-20519.RW2"
1984.987: Adding master versions
1984.988: Scanning file "F:/Digital Pictures/2012/12/LX3-20520.RW2"
1984.993: Scanning file "F:/Digital Pictures/2012/12/LX3-20521.RW2"
1984.994: Scanning file "F:/Digital Pictures/2012/12/LX3-20522.RW2"
1984.996: Scanning file "F:/Digital Pictures/2012/12/LX3-20523.RW2"
1984.998: Scanning file "F:/Digital Pictures/2012/12/LX3-20524.RW2"
1985.0: Scanning file "F:/Digital Pictures/2012/12/LX3-20525.RW2"
1985.2: Scanning file "F:/Digital Pictures/2012/12/LX3-20526.RW2"
1985.4: Scanning file "F:/Digital Pictures/2012/12/LX3-20527.RW2"
1985.6: Scanning file "F:/Digital Pictures/2012/12/LX3-20528.RW2"
1985.7: Scanning file "F:/Digital Pictures/2012/12/LX3-20529.RW2"
1985.14: Adding master versions
1985.15: Scanning file "F:/Digital Pictures/2012/12/LX3-20530.RW2"
1985.20: Scanning file "F:/Digital Pictures/2012/12/LX3-20531.RW2"
1985.22: Scanning file "F:/Digital Pictures/2012/12/LX3-20532.RW2"
1985.24: Scanning file "F:/Digital Pictures/2012/12/LX3-20533.RW2"
1985.26: Scanning file "F:/Digital Pictures/2012/12/LX3-20534.RW2"
1985.28: Scanning file "F:/Digital Pictures/2012/12/LX3-20535.RW2"
1985.30: Scanning file "F:/Digital Pictures/2012/12/LX3-20536.RW2"
1985.32: Scanning file "F:/Digital Pictures/2012/12/LX3-20537.RW2"
1985.34: Scanning file "F:/Digital Pictures/2012/12/LX3-20538.RW2"
1985.36: Scanning file "F:/Digital Pictures/2012/12/LX3-20539.RW2"
1985.42: Adding master versions
1985.43: Scanning file "F:/Digital Pictures/2012/12/LX3-20540.RW2"
1985.48: Scanning file "F:/Digital Pictures/2012/12/LX3-20541.RW2"
1985.50: Scanning file "F:/Digital Pictures/2012/12/LX3-20542.RW2"
1985.51: Scanning file "F:/Digital Pictures/2012/12/LX3-20543.RW2"
1985.53: Scanning file "F:/Digital Pictures/2012/12/LX3-20544.RW2"
1985.56: Scanning file "F:/Digital Pictures/2012/12/LX3-20545.RW2"
1985.58: Scanning file "F:/Digital Pictures/2012/12/LX3-20546.RW2"
1985.60: Scanning file "F:/Digital Pictures/2012/12/LX3-20547.RW2"
1985.62: Scanning file "F:/Digital Pictures/2012/12/LX3-20548.RW2"
1985.63: Scanning file "F:/Digital Pictures/2012/12/LX3-20549.RW2"
1985.70: Adding master versions
1985.71: Scanning file "F:/Digital Pictures/2012/12/LX3-20550.RW2"
1985.76: Scanning file "F:/Digital Pictures/2012/12/LX3-20551.RW2"
1985.77: Scanning file "F:/Digital Pictures/2012/12/LX3-20552.RW2"
1985.79: Scanning file "F:/Digital Pictures/2012/12/LX3-20553.RW2"
1985.81: Scanning file "F:/Digital Pictures/2012/12/LX3-20554.RW2"
1985.83: Scanning file "F:/Digital Pictures/2012/12/LX3-20555.RW2"
1985.85: Scanning file "F:/Digital Pictures/2012/12/LX3-20556.RW2"
1985.87: Scanning file "F:/Digital Pictures/2012/12/LX3-20557.RW2"
1985.89: Scanning file "F:/Digital Pictures/2012/12/LX3-20558.RW2"
1985.90: Scanning file "F:/Digital Pictures/2012/12/LX3-20559.RW2"
1985.97: Adding master versions
1985.98: Scanning file "F:/Digital Pictures/2012/12/LX3-20560.RW2"
1985.102: Scanning file "F:/Digital Pictures/2012/12/LX3-20561.RW2"
1985.104: Scanning file "F:/Digital Pictures/2012/12/WX150-00011.JPG"
1985.106: Scanning file "F:/Digital Pictures/2012/12/WX150-00012.JPG"
1985.108: Scanning file "F:/Digital Pictures/2012/12/WX150-00014.JPG"
1985.110: Scanning file "F:/Digital Pictures/2012/12/WX150-00015.JPG"
1985.112: Scanning file "F:/Digital Pictures/2012/12/WX150-00016.JPG"
1985.114: Scanning file "F:/Digital Pictures/2012/12/WX150-00017.JPG"
1985.115: Scanning file "F:/Digital Pictures/2012/12/WX150-00018.JPG"
1985.117: Scanning file "F:/Digital Pictures/2012/12/WX150-00019.JPG"
1985.124: Adding master versions
1985.125: Scanning file "F:/Digital Pictures/2012/12/WX150-00020.JPG"
1985.129: Scanning file "F:/Digital Pictures/2012/12/WX150-00021.JPG"
1985.131: Scanning file "F:/Digital Pictures/2012/12/WX150-00022.JPG"
1985.133: Scanning file "F:/Digital Pictures/2012/12/WX150-00024.JPG"
1985.135: Scanning file "F:/Digital Pictures/2012/12/WX150-00025.JPG"
1985.137: Scanning file "F:/Digital Pictures/2012/12/WX150-00027.JPG"
1985.139: Scanning file "F:/Digital Pictures/2012/12/WX150-00028.JPG"
1985.141: Scanning file "F:/Digital Pictures/2012/12/WX150-00029.JPG"
1985.142: Scanning file "F:/Digital Pictures/2012/12/WX150-00030.JPG"
1985.144: Scanning file "F:/Digital Pictures/2012/12/WX150-00031.JPG"
1985.151: Adding master versions
1985.152: Scanning file "F:/Digital Pictures/2012/12/WX150-00032.JPG"
1985.157: Scanning file "F:/Digital Pictures/2012/12/WX150-00033.JPG"
1985.158: Scanning file "F:/Digital Pictures/2012/12/WX150-00034.JPG"
1985.160: Scanning file "F:/Digital Pictures/2012/12/WX150-00035.JPG"
1985.269: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1175.CR2"
1985.276: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1175.CR2"
1985.278: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1176.CR2"
1985.288: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1176.CR2"
1985.290: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1177.CR2"
1985.299: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1177.CR2"
1985.379: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1178.CR2"
1985.386: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1178.CR2"
1985.388: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1179.CR2"
1985.398: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1179.CR2"
1985.697: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1180.CR2"
1985.705: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1180.CR2"
1985.850: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1181.CR2"
1985.858: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1181.CR2"
1985.883: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1182.CR2"
1985.891: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1182.CR2"
1985.949: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1183.CR2"
1985.957: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1183.CR2"
1985.971: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1184.CR2"
1985.978: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1184.CR2"
1986.250: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1185.CR2"
1986.259: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1185.CR2"
1986.354: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1186.CR2"
1986.363: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1186.CR2"
1986.422: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1187.CR2"
1986.430: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1187.CR2"
1986.443: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1188.CR2"
1986.463: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1188.CR2"
1986.476: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1189.CR2"
1986.485: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1189.CR2"
1986.716: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1190.CR2"
1986.724: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1190.CR2"
1986.872: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1191.CR2"
1986.879: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1191.CR2"
1986.922: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1192.CR2"
1986.930: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1192.CR2"
1986.980: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1193.CR2"
1986.988: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1193.CR2"
1987.29: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1194.CR2"
1987.37: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1194.CR2"
1987.293: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1195.CR2"
1987.300: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1195.CR2"
1987.414: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1196.CR2"
1987.421: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1196.CR2"
1987.423: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1197.CR2"
1987.986: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1197.CR2"
1988.67: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1198.CR2"
1988.239: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1198.CR2"
1988.241: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1200.CR2"
1988.417: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1200.CR2"
1988.426: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1201.CR2"
1988.584: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1201.CR2"
1988.701: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1202.CR2"
1988.873: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1202.CR2"
1988.875: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1203.CR2"
1989.52: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1203.CR2"
1989.62: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1204.CR2"
1989.242: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1204.CR2"
1989.320: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1205.CR2"
1989.531: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1205.CR2"
1989.671: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1206.CR2"
1989.852: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1206.CR2"
1989.854: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1207.CR2"
1990.47: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1207.CR2"
1990.49: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1208.CR2"
1990.229: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1208.CR2"
1990.392: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1209.CR2"
1990.584: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1209.CR2"
1990.586: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1210.CR2"
1990.777: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1210.CR2"
1990.782: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1211.CR2"
1990.965: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1211.CR2"
1991.91: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1212.CR2"
1991.297: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1212.CR2"
1991.313: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1213.CR2"
1991.518: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1213.CR2"
1991.520: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1214.CR2"
1991.724: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1214.CR2"
1991.843: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1215.CR2"
1992.37: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1215.CR2"
1992.39: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1216.CR2"
1992.237: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1216.CR2"
1992.248: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1217.CR2"
1992.438: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1217.CR2"
1992.527: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1218.CR2"
1992.728: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1218.CR2"
1992.730: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1219.CR2"
1992.915: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1219.CR2"
1993.46: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1220.CR2"
1993.231: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1220.CR2"
1993.233: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1221.CR2"
1993.413: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1221.CR2"
1993.423: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1222.CR2"
1993.596: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1222.CR2"
1993.713: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1223.CR2"
1993.880: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1223.CR2"
1993.883: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1224.CR2"
1994.77: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1224.CR2"
1994.87: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1225.CR2"
1994.290: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1225.CR2"
1994.483: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1226.CR2"
1994.681: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1226.CR2"
1994.683: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1227.CR2"
1994.862: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1227.CR2"
1994.864: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1228.CR2"
1995.56: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1228.CR2"
1995.168: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1229.CR2"
1995.361: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1229.CR2"
1995.363: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1230.CR2"
1995.566: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1230.CR2"
1995.577: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1231.CR2"
1995.766: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1231.CR2"
1995.879: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1232.CR2"
1996.104: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1232.CR2"
1996.106: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1233.CR2"
1996.306: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1233.CR2"
1996.317: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1234.CR2"
1996.510: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1234.CR2"
1996.616: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1235.CR2"
1996.771: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1235.CR2"
1996.773: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1236.CR2"
1996.922: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1236.CR2"
1996.933: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1237.CR2"
1997.93: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1237.CR2"
1997.153: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1238.CR2"
1997.306: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1238.CR2"
1997.365: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1239.CR2"
1997.520: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1239.CR2"
1997.522: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1240.CR2"
1997.677: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1240.CR2"
1997.791: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1241.CR2"
1997.934: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1241.CR2"
1997.936: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1242.CR2"
1998.84: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1242.CR2"
1998.94: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1243.CR2"
1998.240: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1243.CR2"
1998.328: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1244.CR2"
1998.483: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1244.CR2"
1998.496: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1245.CR2"
1998.656: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1245.CR2"
1998.791: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1246.CR2"
1998.951: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1246.CR2"
1998.953: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1247.CR2"
1999.149: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1247.CR2"
1999.151: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1248.CR2"
1999.316: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1248.CR2"
1999.414: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1249.CR2"
1999.484: waiting...
1999.485: doCancel
1999.486: doCancel
1999.488: doCancel
1999.489: doCancel
1999.490: doCancel
1999.491: doCancel
1999.492: doCancel
1999.508: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1249.CR2"
1999.511: Extracting RAW data: "F:/Digital Pictures/2012/12/G1-1250.CR2"
1999.660: Decoding RAW data: "F:/Digital Pictures/2012/12/G1-1250.CR2"
2000.518: done waiting
2000.575: Unlocking catalog: "G:/Program Files (x86)/Corel/User Files/cache"
2000.577: Unlocking catalog: "G:/Program Files (x86)/Corel/User Files/AfterShot Pro Catalog 2012"
2000.578: Early Cleanup
2000.579: delete globals
2000.580: delete globals
2000.582: delete mid globals
2000.584: delete done globals
afx
System_Drive: N/A
Post by afx »
toglenn wrote:Here's the AS Log. I don't know how helpful it will be as I had to delete the complete directory several times because my original AS version was overwritten by tge new version that would not run.
The one from the non running new version would have been the interesting log of course.
A log of a successful run of the older version is not really helpful to learn why the new one does not run.
And only the last 10 lines or so are needed anyway.
cheers
afx
toglenn
motherboard: asrock
processor: intel i7
ram: 12GB
Post by toglenn »
cheers
afx
I installed 1.1.0.30 again and Windows stopped it from running. I checked the AS directory and no log was created so I guess it's a hopeless case! Even the page at first start up about file placement does appear, just the Windows notice about the program stopping.
afx
System_Drive: N/A
Post by afx »
That is extremely early for it to crash...
No idea then,
sorry
afx
