But how do I now get the outer area smoothly faded please?
None of the built-in masks seem to meet this requirement, even in a tightly cropped 400 x 400 form.
Terry, East Grinstead, UK
That worked after a fashion, but the result changed each time I clicked in the area. And I wasn't intuitively comfortable with what I was doing.LeviFiction wrote:Well, you can re-fill it with white and it should mix with the background in the feathered areas.
That didn't fade to black, just to light grey.You can also use a blur command on the white circle such as Gaussian or any of the others PSP provies.
That too did not fade to black.You could also invert the selection and fill with black. This would make the white circle smaller though.
That worked fine thanks. It needed use of Edit on the gradient but after some trial/error I got a good result.You can also fill in the white area with a simple white to black sunburst gradient.
Thanks, I thought I'd specified PSP 8 but see that I didn't, sorry!hartpaul wrote:Also make a black layer and then do Effects --> Photo Effects--> Vignette in X4 and adjust to get desired size and amount of blur.
