zPerspector in ASP 1.1.0.30 for Nikon D800
AfterShot Pro Plugins
tintin
processor: Ryzen R5 3600X
Re: zPerspector in ASP 1.1.0.30 for Nikon D800
Post by tintin »
hi,
can you please try this version... it should improve your problem...
(the version is for windows and linux, if it is ok i will care for the mac version as well)
https://dl.dropboxusercontent.com/u/804 ... WL.afzplug
br
tintin
my plugins on the official plugins homepage
If you find my plugins helpful, please make a donation to support further developments - just click here, thank you!
ubuntuuser
operating_system: Linux
System_Drive: N/A
Post by ubuntuuser »
It looks a lot better. The problem with the grid seems to be gone, but 1 time I was shocked, I saw a red rectangular area, probably a little bit transparent, after I modified the corners. The size of this red area was about 10% of the monitor. I couldn't reproduce it a 2nd time. Old zPerspector xmp-files do not work anymore. A batch with over 40 old photos was finished extremely fast, 0.3 sec for a photo, normally it takes 5-10 sec. To say it in other words, there are no perspective corrections with old files. Thanks a lot for your work!
tintin
Post by tintin »
thanks for your feedback!
that the 'old' xmp-files do not work anymore is not normal.
i did absolutely nothing change on the internal processing engine. all modifications are 'just' about stability improvements. could you maybe try to clean up your cache for processing these 'old' files?
br
tintin
ubuntuuser
System_Drive: N/A
Please tell me what I have to do, to clean the cache?
Do you mean
Code: Select all
rm -r ~/.AfterShotPro/cache/*
tintin
Post by tintin »
i don't know your exact path/directory.
but it should be the sub-directory 'cache' in the asp-settings-folder.
the settings folder of asp can be seen in the preferences of asp (menu 'File' --> preferences --> general --> 'user folder location').
br
tintin
ubuntuuser
System_Drive: N/A
I have lost my zPerspector values (again), it is not enabled, so it is clear, why I cannot see a correction when I process the photos. To loose corrections is very annoying. Maybe this is an ASP "feature"?
Hobgoblin
System_Drive: N/A
Post by Hobgoblin »
@ubuntuuser
I am seeing the same issues that your picture 'wasserhahn.bad_0001.jpg' exhibits.
@tintin
I suspected that this was due to the zFrame, zShadow, zText relationship and experimented ....
I find that by enabling zFrame and setting the size of Frame 1 to 0.01 the lines disappear!
This is with ASP 1.2.0.7 and the latest versions of all the zXxxxxx plugin
Perhaps this will help with the troubleshooting ...
ubuntuuser
System_Drive: N/A
@Hobgoblin
the latest version works fine now-
Which operating system do you use?
zPerspector is the only plugin, which was installed in the last months, after a fresh install of ASP.
My only problem is that I loose the correction of zPerspector somehow.
Hobgoblin
System_Drive: N/A
Post by Hobgoblin »
ubuntuuser wrote:@Hobgoblin
zPerspector 2.1.2
Linux Mint 15
I suspect this may be, at least in part, a graphics driver issue.
I now find I cannot repeat it on another installation with a different graphics card! :?
Since the JPEG output does not contain the lines I am happy to put this down to another of the many quirks that ASP exhibits.
Thanks for you interest
R.
ubuntuuser
System_Drive: N/A
ii libdrm-nouveau1a 2.4.46-1ubuntu0.0.0.1
ii libdrm-nouveau1a:i386 2.4.46-1ubuntu0.0.0.1
ii libdrm-nouveau2 2.4.46-1ubuntu0.0.0.1
ii xserver-xorg-video-nouveau 1:0.0.16+git20111201+b5534a1-1build3
Hobgoblin
System_Drive: N/A
Post by Hobgoblin »
Indeed, but I have a Radeon Graphics Card.
In general terms the driver in the Mint distribution is better than the now deprecated AMD offering. :(
R.
ubuntuuser
System_Drive: N/A
Unfortunately the problem is not solved. I had a very weird situation, the 1st photo of the series of a Sony RX100 (arw) showed the bug, while the 2nd photo did _not_ After a few crashes of ASP the grid in the 1st photo could not be seen anymore.
Code: Select all
dpkg -l | grep -i afters
ii  aftershotpro                                                174:1.2.0.7                                         Corel AfterShot Pro
zPerspector_v2.1.2_WL.afzplug
Xubuntu 12.04
Code: Select all
uname -r
3.2.0-60-generic
Code: Select all
dpkg -l | grep -i nvidia
ii  nvidia-319                                                  331.20-0ubuntu0.0.1                                 Transitional package for nvidia-331
ii  nvidia-319-updates                                          331.20-0ubuntu0.0.1                                 Transitional package for nvidia-331-updates
ii  nvidia-331                                                  331.20-0ubuntu0.0.1                                 NVIDIA binary Xorg driver, kernel module and VDPAU library
ii  nvidia-331-updates                                          331.20-0ubuntu0.0.1                                 NVIDIA binary Xorg driver, kernel module and VDPAU library
ii  nvidia-common                                               1:0.2.44.2                                          Find obsolete NVIDIA drivers
ii  nvidia-settings                                             331.20-0ubuntu0.0.1                                 Tool for configuring the NVIDIA graphics driver
ii  nvidia-settings-319                                         331.20-0ubuntu0.0.1                                 Transitional package for nvidia-settings
ii  nvidia-settings-319-updates                                 331.20-0ubuntu0.0.1                                 Transitional package for nvidia-settings
See photos attached.
tintin
Post by tintin »
hi,
sorry for the late reply.
do you see that black lines only in the ASP or also on the output images?
br
tintin
ubuntuuser
System_Drive: N/A
Sorry, I didn't test this time, if the lines are in the output.
The lines in the sample before disappeared in the output after I changed the graphics-driver. In the meantime I processed a lot of photos without any problems. It is a mad thing, but I think I should leave a note about this. My main problem at the moment is, that ASP doesn't work with the newest Linux distributions. See http://forum.corel.com/EN/viewtopic.php?f=94&t=53471
