zPerspector in ASP 1.1.0.30 for Nikon D800
AfterShot Pro Plugins
pekkal
operating_system: Linux
System_Drive: N/A
processor: AMD Phenom 9500 x 4
ram: 4GB
Video Card: NVIDIA GeForce GT 610
Post by pekkal »
Has anybodey (else) noticed issues with zPerspector with the most recent ASP version and very large files?
I have Nikon D800 and I've had the issue some batch output jobs taking very long time. possibly forever. I believe this only happens when I have zPerspector applied to D800 raw output batch using ASP 1.1.0.30, and when the output file size is large. I never had the issue with D700, and I am pretty sure the previous official (not Beta) ASP ran OK with my D800.
While writing this note I've had batch output for one picture ongoing for ½h or so...
Corel folks: I have submitted an error report...I'd like to update it but I have no link to it.
pekkal
albernier
Re: zPerspector in ASP 1.1.0.30 for Nikon D800
Post by albernier »
same thing for me ( D800) with many plugins... Zframe din't work, so I switched back to previous version 1-0-1-10...
Trucks
System_Drive: N/A
motherboard: 64bit
processor: quad
ram: 3GB
Video Card: Nvidia
sound_card: onboard
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: Eizo S2243 W
Post by Trucks »
Did you update the plugins?
Trucks
albernier
Post by albernier »
You'r right, I did'nt . Thank you, I'll try again.... But the problem remains
jp_wieseth
motherboard: ASRock 890GX Pro3
processor: AMD X6 1100T
Video Card: ATI HD6670
sound_card: onBoard
Hard_Drive_Capacity: 2 TB
Monitor/Display Make & Model: Samsung SyncMaster S27A850D 27"
Post by jp_wieseth »
i have the same problems with D800 RAW-Files (many crashes), so I switched back to previous version 1-0-1-10...
ubuntuuser
System_Drive: N/A
Post by ubuntuuser »
I have the problem with arw-files and a Sony RX 100, using AfterShot vers.: 1.2.0.7 and zPerspector_2.0.1_WML. Compare my posting http://forum.corel.com/EN/viewtopic.php ... 30#p281983
tintin
processor: Ryzen R5 3600X
Post by tintin »
hi,
sorry for the late reply!
the problem sounds indeed similar to the issues with zFrame and zShadow in the past.
but i need to check it in detail (i'll try to o this still this weekend).
i'll keep you updated...
br
tintin
my plugins on the official plugins homepage
If you find my plugins helpful, please make a donation to support further developments - just click here, thank you!
tintin
Post by tintin »
hi,
quick update....
... i found an inconsistent piece of code that indeed could be the root cause.
i'm now about to fix it... hoping to get it done soon.
br
tintin
tintin
Post by tintin »
hi,
even if it took more time than expected, i finally can offer an update of zPerspector with improved stability (please provide information if you still discover some stability problems with this plugin).
changelog:
  • stability improvement
  • integration in 'asPluginManager'
the package is available for all three platforms under following link...
https://dl.dropboxusercontent.com/u/804 ... ML.afzplug
br
tintin
ubuntuuser
System_Drive: N/A
While zPerspector_v2.1.1_WML.afzplug works a lot better with batch processing, there is a bug with the grid changing the rotation, but it looks like it doesn't influence the batch result. Please see the attachment.
grid error with zPerspector_v2.1.1_WML
tintin
Post by tintin »
mh,
i did not yet notice this with my PCs. but i will check it detailed.
i'm quite sure that it is not visibe in output and also in 100% zoom it is not visible, right?
br
tintin
ubuntuuser
System_Drive: N/A
I am pretty sure, it doesn't influence the jpg-output. But it is very confusing to see all the lines. I never saw this with earlier versions. If you think, I should check, I can try it with another linux pc with a different graphics adapter, but both are Nvidia. It depends on the photo and the amount of the rotation, but it could be a lot more confusing than shown with the sample.
ubuntuuser
System_Drive: N/A
The grid can be seen in rendered photos under certain circumstances. Unfortunately I am not sure, when. It looks like, rotate doesn't influence it wiht PEF, but if you correct the 4 corners, it happens.
Edit: An Sony-ARW-file shows the grid with rotate only too!
tintin
Post by tintin »
hi,
sorry for my late reply - i have been away some days...
i could not yet reproduce the problem with my PC, but i think i know how to improve it. so will create a test version for you within the next days....
br
tintin
ubuntuuser
System_Drive: N/A
Thanks a lot, if you want a sample raw-file, let me know. It happens here always, It doesn't help to set to grid to 1 from 256 (default). Changing the grid value doesn't create a visible grid. Rotation and "changing the corners" creates an ugly grid and the grid changes depending on the value. Resetting zPerspector removes the grid.
Edit: Simply enabling zPerspector with the checkbox without modifying any values shows the grid.
