1.1.0.30 Linux RPM install fails
Bugs & Suggestions
lenb
operating_system: Linux
System_Drive: N/A
motherboard: Intel DZ77RE-75K
processor: Intel Core i7-3770K CPU at 3.50GHz
Video Card: Radeon HD 4350 4550
Monitor/Display Make & Model: Dell U2412M
Post by lenb »
I was delighted to see ASP advertise an update today.
But it doesn't install on Fedora Core 16, since
RPM claims that the new version is older than the currently installed version:
# rpm -i AfterShotPro_i386.rpm
package AfterShotPro-174:1.0-1.10.i386 (which is newer than AfterShotPro-174:0.0-0.0.i386) is already installed
file /opt/AfterShotPro/bin/AfterShotPro from install of AfterShotPro-174:0.0-0.0.i386 conflicts with file from package AfterShotPro-174:1.0-1.10.i386
lenb
System_Drive: N/A
workaround for mis-numbered RPM
Post by lenb »
It appears that the update failed because the new RPM is mis-numbered
(or perhaps, not numbered at all)
Erasing the old one and installing the new one from scratch seems to work:
# rpm -q AfterShotPro
AfterShotPro-1.0-1.10.i386
# rpm -e AfterShotPro
AfterShotPro-0.0-0.0.i386
Help/About banner now shows 1.1.0.30
Curiously, the release notes for this update say that "RAW Noise" is enabled by default,
but it seems to be un-checked when I examine NEF's with this version, just like in the previous version.
RickHeath
Re: workaround for mis-numbered RPM
Post by RickHeath »
lenb wrote:Curiously, the release notes for this update say that "RAW Noise" is enabled by default,
Remember that ASP won't alter have already been touched by it, only newly-viewed files. Any camera defaults you have may also override the new default setting (assuming it is there in the 1st place - I haven't ascertained whether this is the case or not).
Rick.
DaPhotograf
System_Drive: N/A
Hard_Drive_Capacity: 250
Re: 1.1.0.30 Linux RPM install fails
Post by DaPhotograf »
I 've the same problem discribe in #1 post.
I've download the rpm wich is on corel's site.
But it's the 1.0.1.10, and not the 1.0.1.30 wixh is dl !
SteveCase
System_Drive: N/A
motherboard: ASRock 990FX Extreme4
processor: AMD FX-8350
ram: 16.0 GB
Video Card: GTX 550ti
Post by SteveCase »
Steve in Seattle,WA
