ufo file extension
lynchryl
ufo file extension
Post by lynchryl »
Using VS8 I was trying to view .ufo file extensions that I had saved from VS 6. I inadvertently changed the program used to open these files. I had been able to view them prior to the accidental change. I posted this question on the old WeBoard and the only reply said to use Ulead PhotoImpact, but I don't have this program. Does anyone know what program I should use? My upgrad to VS 8 only has one menu template and I would like to have my old ones be usable. Thanks,
Lyn
htchien
operating_system: Mac
Post by htchien »
You can only use Ulead PhotoImpact to read or modify the .ufo file. You can download a trial version of PhotoImpact to use, but it will have some trial period and you will not be able to use it after the trial period is expired.
If you think PhotoImpact is good for you, you can consider to buy it. If you do not want it after the trial period is expired, you can just remove it from your system.
Hope this helps.
H.T.
Post by Trevor Andrew »
copy and paste the .*ufo files to
C:\Documents and Settings\Your Name\My Documents\Ulead VideoStudio\8.0\My Favorites
you should be able to view in the menu stage my favorites
