Transition insertion to work on overlays as well
Ken Veal
motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
processor: 360 gigahertz Intel Core i9 900K
ram: 32 GB
Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
Hard_Drive_Capacity: 1250GB SSD
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Post by Ken Veal »
X5 Pro Ultimate
Default colour duration 6
Default transition effect 4
Jpeg images in overlay tracks (3 or 4)
As part of a slideshow I have applied transitions inbetween the colour clips but they are only working in the video track colours and not the images in the overlay tracks that are on top of the colours tracks.Is there any way of getting the overlays to transition too? ...................Ken
Re: Transition insertion to work on overlays as well
Post by BrianCee »
Not sure what you mean by "default transition effect 4" - is that a standard transition - then it will have a name like "burn", "box" or "crossfade"
either way unless your transition is something special then in version X5 you can apply transitions straight into the overlay track, so just add whatever transition you have applied to the colour blocks to the join between the jpegs and set the same time duration as the one in the top track.
pvreditor
processor: Intel i7
ram: 24GB
Hard_Drive_Capacity: 2TB
Post by pvreditor »
If you want to do transitions from the main video track to the overlay tracks and back again, I have a tutorial video about that. You can see it at:
http://forum.corel.com/EN/viewtopic.php?f=27&t=48554
Keep in mind that whatever you have on the overlay tracks will always show in preference to what you have on the main video track. If you have color clips in the overlay tracks, they will block whatever you have in the main video track.
Hope that helps!
Bob Kovacs
http://www.bobkovacs.com
Ken Veal
ram: 32 GB
Post by Ken Veal »
Preferences-edit tab-
Default transition effect duration-a value of 4 has been entered in the box.To the right of the box is 1....999 sec(s)
Ditto for colour duration
Post by BrianCee »
OK so that's a time setting - not a transition number.
surely an image time of 6 seconds and a transition of 4 seconds doesn't give you much time to view the image.
Ken Veal
ram: 32 GB
Post by Ken Veal »
That is right, much too short, that is another mistake on my part.Can I lengthen this without causing a load of Sync issues?-Not had a chance to look at the link yet-thanks though.
