PSP X5 button icons wrong
sholmes1
motherboard: Intel D875PBZ
processor: Intel Pentium 4 CPU 3.00GHz
ram: 2GB
Video Card: RADEON X850 Series
sound_card: Sound Blaster Audigy 2
Hard_Drive_Capacity: 300GB
Monitor/Display Make & Model: LG Flatron IPS236
Post by sholmes1 »
I just installed PSP X5 Ultimate (full install). After it completed it installed an update. All appeared to go fine. I opened the program and went to EDIT. I am familiar with PSP as I have used a number versions up to X2. The first thing I tried to do was crop a photo. The crop tool buttons are not correct. The "Apply", "Crop as new image" and so on under the crop area window are not correct. I see a square of colors. I see the same thing on the main tool bar for the "Copy Special" function and the "Share" button. There could be more that I have not discovered yet. I rebooted and tried again, but get the same thing. Also, the button icons look different each time I load.
Anyone else see this or know what to do?
Kathy_9
Hard_Drive_Capacity: 2TB
Re: PSP X5 button icons wrong
Post by Kathy_9 »
I have a similar issue with icons that change themselves back and forth at will. My incorrect icons are on the Layers Palette. I reported this during beta testing but it seems to be a random occurrence that will self-correct and then switch back again to the incorrect icons. Since it's so random, doesn't effect everyone and almost impossible to replicate I don't hold much hope of a fix.
What you can try is to reset your workspace as that seems to correct a multitude of things. First, and especially if you have done any customization, you should save your workspace and then close the program. Next while holding down the shift key click on a desktop icon for PSP. It will ask you something to the effect of "do you want to revert to factory defaults". Click yes or okay (I forget what it says) and see if your icons have returned to normal.
As you can see these are not the correct icons on the layers palette.
sholmes1
ram: 2GB
Post by sholmes1 »
Thanks for the suggestion, but I tried the 3 methods to restore I found in the knowledgebase. I held shift while running the program to restore to the default state. I then ran the restore database program and then renamed the 15.0 folder in the Application Data Folder, but still the same icons are wrong. I looked and my layer icons are fine. It is the same ones that are wrong each time. I wonder were the program gets that icon from? Maybe there is a problem with that file. I have not uninstalled/installed yet. I wrote to customer support to see what they think, but what I got back so far is to do what I have done.
sholmes1
ram: 2GB
Post by sholmes1 »
I found many more icons that are wrong by turning on different toolbars. I also found that if I right clicked on the toolbar and selected customize and then the options tab and checked "Show small icons" then all the icons are fine. If I uncheck it the bad icons are back. I wonder why some of the large icons would be wrong?
Kathy_9
Post by Kathy_9 »
I don't know what the reason is but it is very random and seems to impact people differently or not at all. One good thing is that if you have the screen tips turned on via the Customize -> Options menu, you will see the correct description when you hover the mouse over the icons.
I tried your method of switching to small icons to see what would happen and I did not get the same result you did. As soon as I clicked on small icons, my incorrect icons were overlaid with the words RAW and JPG (screen shot below). When I clicked okay to accept the change to small icons, the incorrect icons were still there; just smaller and the words RAW and JPG disappeared.
Would I like to see this fixed? YES!! Do I think it will happen? Probably not.
sholmes1
ram: 2GB
Post by sholmes1 »
That is a strange problem. Looks like your issue is it shows an icon that is different than what it should be. For my icons that are incorrect it shows a random colored square (when on large).
I hope they can fix it too, but who knows.
I do notice that this version is a lot slower than X2. Atleast on the computer I am using now. I think it is time to update.
teknisyan
processor: Intel Corel i5
ram: 4 GB
sound_card: Realtek HD Audio
Hard_Drive_Capacity: 500 GB
Post by teknisyan »
You may want to download and install the update for PSP X5 - http://www.corel.com/corel/pages/index. ... id=5000003
and the directx -
Direct X: http://on-msn.com/aLrk0j (WinXP)
Direct X: http://www.microsoft.com/Windows/window ... tx-11.aspx
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
Kathy_9
Post by Kathy_9 »
Abiel,
Thanks for your suggestions; however, my PSPX5 is fully patched with SP1. In fact, the issues with the incorrect icons occurred after I applied SP1. I reported this on Zen Desk 9/5/12 (ticket #980). Also, I have the current version of DirectX (11) installed.
By the way, your second link for DirectX leads to a page that reads "Meet Windows 8".
Kathy
Joelle
ram: 16 GB RAM
Hard_Drive_Capacity: 1TB
Post by Joelle »
As Kathy mentioned, some users experience problems, others don't.
This is what I see when I use the floating crop toolbar (which I normally don't):
Cute puppy! :-)
Joëlle
Joëlle
(PSPX9 )
sholmes1
ram: 2GB
Post by sholmes1 »
That is what I see when I switched to small icons. The correct icons show then. I am glad that it works one way or another. It would be nice if they could fix it though. When I told customer support that I already did the 3 methods they said "Unfortunately, there is nothing further I can do."
Thanks.... We just got the puppy 2 weeks ago.
Simone Corel UK
Alludo
Post by Simone Corel UK »
at sholmes1
When I look at your system specs, you must have a very old machine and installed a theme, which often cause problems.
motherboard: Intel D875PBZ (Intel website: Date Created: 20-Nov-2005)
processor: Intel Pentium 4 CPU 3.00GHz (2005)
ram: 2GB
Video Card: RADEON X850 Series (2004/05)
No wonder that X5 works slower then X2, which was fine for your hardware. The icons are a graphic card/DirectX issue. The driver must be 4 years if not even 7 years old.
You could think about buying a new machine... Only a suggestion.
Kathy_9
Post by Kathy_9 »
Just to illustrate my point that these icons "come and go" as they please, the correct icons are back on my layers palette today. I didn't do a thing - they just reappeared. :roll:
Joelle
ram: 16 GB RAM
Post by Joelle »
Simone Corel UK wrote:at sholmes1
ram: 2GB
Hmm, that's an interesting observation :-)
My computer:
Windows 7 Home Premium (64-bit)
Intel Core i5 CPU 750@2.67GHz
4.0GB RAM
ATI Radeon HD 4800 Series
Runs X5 without any problems (other than what Corel decides to throw at us, but that's a different story).
But ... I have had to uninstall X2 as it was slower than a snail and drove me nuts.
It doesn't always follow that newer is better.
Just my thoughts :-)
Joëlle
Joëlle
(PSPX9 )
photodrawken
ram: 16Gb
Hard_Drive_Capacity: 324Gb
Post by photodrawken »
Kathy_9 wrote:Just to illustrate my point that these icons "come and go" as they please, the correct icons are back on my layers palette today. I didn't do a thing - they just reappeared. :roll:
Maybe it's because the world ended yesterday. :mrgreen:
Ken
Kathy_9
Post by Kathy_9 »
photodrawken wrote: Maybe it's because the world ended yesterday. :mrgreen:
LOL!! I think that's when Corel will fix it. :P
