I'm using a freshly installed VideoStudio Pro x5, so all settings are standard.
I imported XXX.MTS files (AVCHD) from a camcorder into VSX5.
Info on the files
File format: NTSCVideo Type H. 264
29.97 fps
Audio Type: Dolby Digital
48khz , 2 ch
Bite rate 18.00Mbps
If i preview the files before putting them into the project, there is no sound, movie plays fine.
If i add them to the project and select "project" instead of clip there is sound...
If i add them to the project and select "clip" instead of project there is no sound...
I updated my VSX5 with SP1 but it didn't work...
Hope someone have same issue and found the solution.
Thanks,
using mts file in VSX5 but no sound
Re: using mts file in VSX5 but no sound
have you read this topic - - http://forum.corel.com/EN/viewtopic.php?f=1&t=48647
it seems to have a lot of similarities to your problem
