Any way to change the JPG save defaults ?
Amamba
Post by Amamba »
I just realized that the default is set to 20, which is too aggressive.
However, I don't see the way to change it in preferences.
Do I need to change the compression factor with every single save ? Or is there a way to set it in program defaults ?
LindaSue
motherboard: Gigabyte
processor: 2.71GHz AMD Athlon II X2 215 processor
ram: 3 GB
Video Card: ATI Radeon HD 4350
sound_card: Realtek AC97 Audio [onboard]
Hard_Drive_Capacity: 1320 GB
Monitor/Display Make & Model: Asus MX279 HDMI 27-inch
Corel programs: Paint Shop Pro X2, X4, X6
Re: Any way to change the JPG save defaults ?
Post by LindaSue »
Whatever you set it to, it will remember that setting the next time you save a JPG.
Using Paint Shop Pro versions 5, 6, 7, 8, 9, 12, 14, 16
Amamba
Post by Amamba »
It appears it does it per window so the setting in "Adjust" is diffrent from "Edit".
Thanks !
LindaSue
ram: 3 GB
Post by LindaSue »
I never use Adjust so I'd never noticed that.
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Post by hartpaul »
Just used the Adjust mode in X4 and did a Save As and selected Options to change the save quality to 10. Repeated with another image and Save quality was remembered as 10. Closed X4, reopened and again opened an image and did a Save As and checked the options and the Save Quality was remembered as 10. So no problems here .
