I have Aftershot Pro in my Linux Mint 14 OS.
When I browse for files Aftershot Pro only looks in SDA 1, my system drive.
My archive of RAW image files (about 200gb worth) is on SDA 2.
How can I get Aftershot Pro it look at a different harddrive??
Linux - Browse other hard drive
BitKeeper
- motherboard: P5B Delux
- processor: Intel Q8400
- ram: 4GB
- Video Card: Nvidia GTX 460
- Hard_Drive_Capacity: 11TB
- Monitor/Display Make & Model: Dell 24"
Re: Linux - Browse other hard drive
Where do you have sda2 mounted?
Try looking under /media/<some_dir> or /mnt/<some_dir>.
Dobly
- motherboard: Asus K170-P D3
- processor: Intel i5 6600K 3.5ghz
- ram: 32gb
- Video Card: AMD Radeon 270X
- sound_card: Focusrite 2i4
- Hard_Drive_Capacity: Heaps
BitKeeper wrote:Where do you have sda2 mounted?
That is a good question. I'll check when I get home (@work now).. Even if I knew that, where in Aftershot Pro would i tell it look there. The top most thing on the file broswer is the slash / character (or is it a back slash \ ). Anyway, if the other drive is mounted (which I assume to the case as I can get to from the OS) why can't it be seen?
COULD it be becuase the other drive in NTFS? Should not matter. Just thought I'd put it out there.
Dutchmm
- System_Drive: N/A
- motherboard: Asus 97
- processor: Intel i7 4785T
- Video Card: Onboard Intel
- sound_card: Intel AC97
- Hard_Drive_Capacity: 2.5TB
- Monitor/Display Make & Model: Philips 28"
- Corel programs: ASP 3 Pro (and 2 and 1 before)
Or make a symbolic link from the archive directory to your home directory:
sudo ln -s /opt/archive /home/Dobly/archive
assuming:
/opt is the mountpoint for SDA2 - you can check with the df console command
/home/Dobly is your home directory
you want the picture archive to be visible to all the programs and sessions you start
I believe sudo is one of the base packages that is in every flavour of Mint (although I am still on Maya, and I have only ever used the KDE and the GNOME versions - the latter back in Lisa time).
HTH
assuming:
HTH
afx
- System_Drive: N/A
- Video Card: FirePro 4900
If SDA2 is mounted via the brain dead gfs node, the AS will not see it as AS ignores directories and files starting with a "." (after all they are considered hidden by UNIX conventions).
Only programs that use the appropriate libraries will then see the mount points.
Workaround is either a symlink or using the regular mount mechanism.
cheers
afx
cheers
afx
greerd
- System_Drive: Z
- processor: Intel i7 920
- ram: 12 GiB
- Video Card: nVidia GeForce 260
- sound_card: Onboard
- Hard_Drive_Capacity: 5 TB
- Monitor/Display Make & Model: Dell UltraSharp U2410
Ubuntu 12.10 and Mint 14 changed the media path from /media/somedrive to /media/username/somedrive. Perhaps thats the problem?
Dobly
- ram: 32gb
No.. This one was a PICNIC.. (Problem In Chair, Not In Computer).greerd wrote:Ubuntu 12.10 and Mint 14 changed the media path from /media/somedrive to /media/username/somedrive. Perhaps thats the problem?
Coming fresh out of Window7, I had no idea that the other drives were 'mounted' in a folder on SDA1.
I found the drive in /Media/<username>/<harddrive>
Thanks everyone.
