Problem with rotating aspect ratio of crop
Bugs & Suggestions
tepa74
operating_system: Linux
Post by tepa74 »
Don't really know whether this is a bug, feature or "invalid user error".
If I want to rotate the cropping box eg. change aspect ratio from 2:3 to 3:2 or vice versa, it seems that, when converting image(s) to jpeg dimensions will be wrong. At the moment I have a queue with scaling configured to long edge to be 1500 px, and short edge to be 1000 px. For example I had a picture shot with a horizontal composition and cropped it to result vertically composed picture. After conversion I have a 667x1000 px jpg file, even thouhgt it should be 1000x1500. I haven't found a way to correct this...
Br,
tepa
afx
System_Drive: N/A
Video Card: FirePro 4900
Re: Problem with rotating aspect ratio of crop
Post by afx »
Use the longest dimension in both fields of the scaling. The aspect ratio is then defined by the image.
cheers
afx
tepa74
Post by tepa74 »
*facepalm*
Of course, that's obvious when you stop to think about it... Thanks a lot for help!
tepa
