Hello,
I have installed and updated a trial version of WinDVD 11 Pro in order to test 3D playback of 3D Blu-ray discs using the shutter method. Unfortunately, it didn't work.
description of error:
Although WinDVD recognizes the discs as 3D Blu-ray disc and activates the 3D mode, the projector will only receive a 3D image if the output method is set to "anaglyph". If "HDMI 1.4" is chosen instead, the projector will receive a 2D image only. Strangely, the nVidia 3D Vision mode is even disabled, even though the graphics card is compatible.
set-up:
1) several 3D Blu-ray discs
2) HP EliteBook 8560w with nVidia Quadro 1000M and DisplayPort
3) DP/HDMI adapter and HDMI cable (HDMI 1.4a)
4) Epson EH-TW6000
5) compatible 3D shutter glasses
Thank you very much in advance for your help!
fu--i
Playback of 3D Blu-ray discs in 3D by WinDVD 11 Pro
Moderator: lata
teknisyan
- processor: Intel Corel i5
- ram: 4 GB
- Hard_Drive_Capacity: 500 GB
Re: Playback of 3D Blu-ray discs in 3D by WinDVD 11 Pro
It can be a problem with the COLOR ENHANCEMENT, go to TOOLS > ENHANCEMENTS > VIDEO > Click on the COLOR TAB then select PROJECTOR. Then click on the down arrow beside the "3D" icon (3D SETTING option) then make sure you have the 3D Status turned "ON" and CONTENT TYPE is set to 3D.
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
About Tech
About Sports
Hello Abiel,
thanks for you answer! I will try it as soon as possible and will post the result here.
Best regards,
fu--i
Best regards,
fu--i
Hi Abiel,
obviously, a missing driver for nVidia's 3D Vision functionality was the reason for this problem. The drivers provided by HP were outdated and incomplete.
fu--i
fu--i
