I have a dvd burner that I know is 8x however when I go to burn using Ulead it always says that it is burning at 1.6x or 2xmax. Does anyone know how to get ulead to recognize proper capabilities of burner?
thanks
PEte
proper writing time
I suspect a driver problem... but it could be anything. Are you using 8X blanks?
Here's the process:
Burner's firmware reads information from the blank DVD.
Firmware reports burner's capabilities (and maybe the blank's properties) to the driver.
Driver reports capabilities to the operating system.
Operating system reports capabilities to the application (Workshop).
Oh, is that the actual speed (during burning) or the maximum speed listed before burning?
If it's the actual speed, you have a slow system, or something is wrong with it. Make sure that DMA is enabled on your hard drive(s) and on your burner. Before I turned DMA on, it was taking 40 minutes to burn a DVD. Now it takes less than 10 minutes. (I think the details for turning- on DMA are different on the different versions of Windows.)
Here's the process:
Stoneprod
Thanks for the replies ya'll. I'll be sure to give the DMA a try. Havn't checked to see if this is on or not. My computer is fairly new so I don't think that it is slow. I have had trouble finding places to download new firmware. Any suggestions.
also how does down loading those patches from ulead work?
thanks again for all the help
Pete
Pete
