Editing two images on the same screen
Shanafeg
- Monitor/Display Make & Model: HP LE1901w
I'm a longtime user of PSP 8 and just downloaded the trial version of PSP X5, thinking to buy it. With PSP 8, if I wanted to edit two images on the screen at the same time, I loaded them both into the program and then used the minimize button at the upper right hand of each image to switch them out of full-screen mode and put them next to each other. PSP X5 no longer has the minimize buttons attached to the images. I can tab back and forth from one image to the other, but I can't figure out how to put them both on the screen simultaneously. Is this feature still present somewhere in PSP X5? How do I access it?
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Re: Editing two images on the same screen
On the menu bar select the Window -> Tabbed Documents.
This will disable Tabbed documents and give you back the original MDI windowed mode.
