Changed directory names. How to update catalogs?
afx
operating_system: Linux
System_Drive: N/A
Video Card: FirePro 4900
Re: Changed directory names. How to update catalogs?
Post by afx »
coolrat wrote:Would your recommend using iMatch or Adobe Photoshop Elements as my DAM tool?
PSE is a toy in my eyes.
Since you are using iMatch, I guess you must have many good reasons. Why did you chose iMatch?
That choice was made many years ago.
Scripting is a key reason for me, because as soon as you need more than a bit of basic cataloging users needs vary greatly, so being able to script things becomes important. iMatch is powerful enough to drive business processes in image agencies.
Private namespaces for organizational metadata (iMatch hierarchical categories), stored queries, customizable displays and edit masks are other things that I consider important.
I'm using Windows now, but can envisage a day when I switch back to Linux. Basically I try to use software that is cross-platform (Win, Linux, Mac) to prepare for the day I switch.
Been hoping for that too long to still believe it...
cheers
afx
Dutchmm
System_Drive: N/A
motherboard: Asus 97
processor: Intel i7 4785T
Video Card: Onboard Intel
sound_card: Intel AC97
Hard_Drive_Capacity: 2.5TB
Monitor/Display Make & Model: Philips 28"
Corel programs: ASP 3 Pro (and 2 and 1 before)
Post by Dutchmm »
@coolrat
FWIW, at least the basic functionality of iMatch runs under WINE. I never took my research any further, because my - amateur - cataloguing needs are easily met in AS. But I wouldn't let the lack of a specific linux version put me off buying iMatch if I needed its special sauce features.
Trucks
System_Drive: N/A
motherboard: 64bit
processor: quad
ram: 3GB
Video Card: Nvidia
sound_card: onboard
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: Eizo S2243 W
Post by Trucks »
tried iMatch under WINE and it didnt run. Hangs always when trying to import the RAWs.
Regards
Trucks
ferdinand-paris
motherboard: GA-X58A-UD3R
processor: 3.20 gigahertz Intel Core i7 960
ram: 4Gb
Video Card: NVIDIA GeForce 7300 GS
sound_card: Realtek High Definition Audio on-board
Hard_Drive_Capacity: 2500 Gb
Monitor/Display Make & Model: Eizo CG222W
Post by ferdinand-paris »
afx wrote:
coolrat wrote:I have downloaded iMatch and will try it out.
It has a long steep learning curve.
But it is extremely powerful.
Powerful? Yes. Long, steep learning curve? I wouldn't have said so. If you haven't used a real DAM then are some new concepts to familiarise yourself with. And any program that is powerful is by its very nature deep, which means that you can continue to learn for a long time should you choose to. But there are some basic concepts that you can learn quite quickly and get yourself up and running. And unlike here, you can usually get prompt interaction with the developer when needed.
F_P
Dutchmm
System_Drive: N/A
Post by Dutchmm »
Trucks wrote:Hi,
Regards
Trucks
Bizarre! Cataloguing images works for me (Sony ARW from my A55) on Crossover 11.3 running on Lisa Maya KDE (32 bit). Some operations are slow, but then I am running on a laptop with only 3G of RAM.
