Getting rid of image join.
Norfolkman6
motherboard: Lenovo LNVNB161216 U3E1
processor: Intel Core i3
ram: 4GB
Video Card: Generic PnP Monitor on Intel HD Graphics 620
sound_card: Speaker HP Realtek High Definition Audio
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: Generic PnP Monitor on Intel HD Graphics 620
Corel programs: PSP X3 X5 X6 X7 X8 X9 PSP2019
Post by Norfolkman6 »
I am using PaintShop Pro X5 & PaintShop Photo Pro X3
I have an image which was originally made up of two other images side by side. They are both of similar colours and content but the dividing line between them is quite obvious. I don't have the original PSP files in order to use the selection and layer method of feathering them, so what would be the best way to get the pixels to blend across the join? I thought there was a tool in PSP to do this but can't find anything. Googling doesn't seem to help much either.
Any advice would be much appreciated.
Geoff.
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Re: Getting rid of image join.
Post by hartpaul »
Have you tried the blemish fixer tool. (sub tool in the Makeover tools) . I have found it useful for a lot of things where you need to get some seamless fills.
Also possibly the scratch remover tool (sub Clone tool) . Both of the tools mentioned take samples outside the central area and use that to fill the area including your join.
Norfolkman6
ram: 4GB
Many thanks,
I'll give those a try.
wds937
motherboard: Dell 0HN7XN A01
processor: Intel Pentium Dual Core E5800 - 64-bit - 3.20 GHz
ram: 4 GB
Video Card: Intel G41 Express - integrated
sound_card: Realtek High Definition Audio - integrated
Hard_Drive_Capacity: 320 GB
Monitor/Display Make & Model: ASUS VS247
Post by wds937 »
I have used several techniques for this purpose, and it often depends on just how similar (or not) the two pictures are, and how bad the seam appears. This technique should give satisfactory results for many situations. Use it as a guide, varying the numbers to your individual work and preferences.
  • Create a selection that bridges the seam. Make the selection the height of the picture if the seam is vertical, or the width of the picture if the seam is horizontal. Have the selection overlap the seam by 32 pixels on each side. The Selection type should be Rectangle, and use 8 for the Feather value.
  • Adjust > Blur > Gaussian blur.... Set the Radius to 8.00, and then click OK.
