Menu Options
GorHar
Menu Options
Post by GorHar »
I am trying out the DVD MovieFactory 7 trial version. I've created a DVD and when I play the first slideshow, it continues to the second slideshow after the first one finishes. I want the DVD to return to the main menu after each slideshow plays. How do I do that ?
Also I have 3 photo slideshows on the main menu, but I want to add a movie as the fourth menu item. Can this be done ?
Re: Menu Options
I do not have Movie Factory installed at the moment, I use Video Studio, I would recommend trailing that as well as MF. The burner module is similar.
To the lower left are a few icons, the gear / cogwheel opens a window, the lower panel should be navigation controls,
Take out the tick then select Back to Menu, this works for Title/Main menu, it will not control the chapter menu.
I assume your Slide Shows are a video file a mpeg2, your video will be/should be the same.
For each file you add to the timeline a link is created on the main menu page.
The only limitation is the overall size in GB, a standard disc holds 4.3 Gb of data
