Hello,
I added a flash animation as an overlay track but cannot get it to extend further than the original animation length, I am trying to have the animation as a background throughout the video.
Any ideas in how to do this would be great.
Thank you in advance.
Why Can't I Extend/Drag a Flash Animation
Re: Why Can't I Extend/Drag a Flash Animation
Even if you could extend a Flash animation and you extended it for a long project it would run so slowly you possibly wouldn't even see any movement - for instance if your animation has a pattern revolving once per minute and you could extend the animation to 30 minutes it would mean that your pattern now took 30 minutes to revolve once.
As I see it you have two options - one is to make a flash animation for the length you want the project to run - and two is just to insert copy after copy after copy of the animation into the overlay track until you reach the length of the project.
Thanks Brian,
Appreciate and understand.
Thank you very much for the help.
