I have ProX3 and am trying to create .mov PhotoJPEG video clips. I'm trying to decrease the compression quality since I'm uploading these clips to stock video footage websites. However, when I go to export the video, under the Compression screen the Quality area is grayed out at 100% and won't let me move the tab over to decrease it. Any suggestions on how to change it?
Decreasing compression quality when exporting
Daytonagrl24
- processor: intel core i7 quadcore
- ram: 6gb
- Hard_Drive_Capacity: 600 gb
Re: Decreasing compression quality when exporting
The Speed ---Quality slider affects the way the encoder reads the files, Although that may affect the final quality it will not affect the file size.
At 100% the encoder will take longer to create the file.
Normally you would adjust the Data Rate to control quality against file size.
Photo-Jpeg does not seem to allow this and indeed reflects in the size or the files.
Do you specifically require Photo-Jpeg compression?
If you require a smaller file size try the Mov—Mpeg4 Visual
Daytonagrl24
- ram: 6gb
Hi Trevor, thanks for the tips. Yes, unfortunately I submit videoclips to istockphoto.com and they require a PhotoJPEG or MotionJPEG format only. I was hoping to bring the file sizes down somewhat because a 15 second clip rendered at 100% quality in PhotoJPEG is taking 15 mins or more to upload to the site. I suppose changing the video width and height could speed up the process? I'm completing them at 1920x1080 right now. Would changing it to 720x480 help?
Daytonagrl24
- ram: 6gb
Does anyone know if changing the video height and width size can help with compression quality issues? Instead of doing 1920x1080, create 720x480?
It does seem strange that you are limited to these two formats.
Photo Jpeg is a Quicktime Mov type, as far as I know
I have a Lumix camera that records to Photo-Jpeg at 250Mb per minute, now that to me is extremely high. I convert these to Mpeg4 at 35 MB for upload to You Tube. 1280 x 720
If your original video files are HD then they are widescreen 16:9.
By the way can you tell us what are the properties of the original files.
Converting these to 720 x 480 is downscaling the HD to SD and with it the quality. You may also be changing the aspect ratio from 16:9 to 4:3 which may result in black borders?
If you wish to downscale then use 1280 x 720. (16:9)
Further reduction to 512 x 288 would retain the aspect ratio 16:9, what the quality would be like is anybodies guess. Run a few tests.
I doubt if changing the frame size is going to impact on the file size, you would have to change the compression type.
Update, I just tried 512 x 288 and the file was larger than the original at 344Mb, remember that’s one minute of video. don’t use Photo-Jpeg.
I assume by now you have tried a few options.?
