If I install Paint Shop Pro X5 (PSP) and its service pack in Windows 8, then Windows Explorer (WE) crashes whenever I navigate to the "My Pictures" folder (or a sub-folder of My Pictures). WE displays the folder for about 2 seconds - then it just goes away - as though the window had been closed. Actually WE crashes. Even if I exit PSP the same thing happens. But if I un-install PSP, then it goes back to normal, that is, I can then browse My Pictures and its sub-folders with WE.
When I look in Control Panel\System and Security\Action Center\Reliability Monitor
I see "Windows Explorer Stopped working ..."
A right-click and "View Technical Details" then shows the following in Control Panel\System and Security\Action Center\Problem Details
Description
Faulting Application Path: C:\Windows\explorer.exe
Problem signature
Problem Event Name: APPCRASH
Application Name: explorer.exe
Application Version: 6.2.9200.16433
Application Timestamp: 50763312
Fault Module Name: PSPPThumbShellExt64.dll
Fault Module Version: 15.0.0.1
Fault Module Timestamp: 4fc2ea43
Exception Code: c0000005
Exception Offset: 0000000000032080
OS Version: 6.2.9200.2.0.0.256.48
Locale ID: 1033
Additional Information 1: f7d1
Additional Information 2: f7d100bded199761aefed8116d21d73c
Additional Information 3: 9190
Additional Information 4: 91907475546ad2acca71fea16802e922
Extra information about the problem
Bucket ID: 99234b1e07c8c0afa18bac14b4c73b99 (84551217)
I am running 64-bit Windows 8 Pro on an ASUS slate tablet EP121.
I run WE with the option "Launch folder windows in a separate process".
During the PSP install, I clicked on check for updates, and it down loaded the PSP X5 service pack. I then exited PSP and it Installed the service pack.
When PSP was installed, I tried the PSP command that shows a file in Windows Explorer, and that seemed to work fine. But using Windows Explorer normally always crashed.
I submitted a report to Corel support.
-Rob
PSPPThumbShellExt64.dll crashes My Pictures folder
photodrawken
- ram: 16Gb
- Hard_Drive_Capacity: 324Gb
Re: PSPPThumbShellExt64.dll crashes My Pictures folder
It's not too surprising that an application-supplied system DLL could have a conflict with a newly released operating system. You did the right thing to supply the details to Corel.RobOppen wrote:I submitted a report to Corel support.
Ken
RobOppen
- motherboard: ASUS EP121
- processor: Intel Dual-Core i5 470um
- ram: 4GB
- Video Card: Intel HD Graphics Revision 18
- Hard_Drive_Capacity: 121GB
- Monitor/Display Make & Model: ASUS EP121.
A reinstall appears to have fixed it.
First I uninstalled PSP and Rebooted.
And verified that the problem was gone, i.e. I could browse My Pictures folder.
Then I installed PSP again. And it seems to be OK.
This time I ran PSP (and edited a picture) before installing SP1 (no problem)
then it auto installed SP1 (still no problem).
Also this time I delayed registering it - I did not give it my email address to register- because it wont let me copy and paste it in and I felt it was too long to bother with. But I later did register it.
[Last time I registered it during the install and clicked on "check for updates" so I installed SP1 immediately after installing PSP and before actually using it]. Probably not a significant difference, but who knows?
In any case, if you experience this (where My Pictures folder appears to close itself) then try uninstalling and re-installing.
Also tell Corel support - they had a quick fix patch that might help - but I have not tried it - at least not yet.
However I experienced a different problem - PSP would not start. It did once, but then it wouldn't.
I signed out (logged off) of Windows 8 and back in - and then PSP was able to run OK.
So for now, PSP is running OK under Win8 on my Slate.
-Rob
-Rob
photodrawken
- ram: 16Gb
Sounds good.
Ken
jukka
- System_Drive: B
- processor: thunderbolt
- ram: 32bmw
- Video Card: s3 triodent
- Monitor/Display Make & Model: whaat?! 4 monitors. Yup! 4
- Corel programs: psp 2020, videostudio 2019
This is happening for me with windows 7 64 and PSP X3
does not matter if the app is closed or open.
But not with every folder. Seems that folder (or it's sub) has a very short and wide .png and .pspimg files with transparency.
Corel shold figure out the rest and fix this
Problem signature:
Application Version: 6.1.7601.17514
Application Timestamp: 4ce7a144
Fault Module Version: 3.0.0.0
Fault Module Timestamp: 4c03606b
Exception Offset: 00000000000012fd
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1035
Additional Information 1: b287
Additional Information 2: b287e9507005724926d2d81d400c25ab
Additional Information 3: 01a5
Additional Information 4: 01a54a17541bd40f685838f8d13a1947
Problem signature:
Locale ID: 1035
I can reproduce the crash of explorer. New install of PSP X3 does not solve the issue.
Today I changed the size of a .pspimage-file to 32x5000 pixel. Before it was 32x4000 pixel. After that change the explorer crashes when open this folder in explorer with file-preview is active. The pure file list works fine.
So there could be a buffer overrun or something else. But there is no support for X3 any longer
