How to turn off automatic transitions?
Mark Swanson
motherboard: Dell OJCTF8
processor: intel i7 6700
Video Card: AMD Radeon R7 350
Hard_Drive_Capacity: 1 tb
Post by Mark Swanson »
Hello folks!
Hey, I cannot figure out how to turn off the "add automatic transition" function. I am using VSx4. I can go to Settings>Preferences> and hit the Edit tab, and I make SURE that the "automatically add transition effect" box is NOT checked, click OK but there is still a transition that gets added when two clips are placed next to each other. I turned on the function to check it out, and now I want to get rid of it, and can't find out how to get it to go away!
Please advise. Thanks!
  • Mark Swanson, guitarist and luthier
canuck
operating_system: Windows 8.1
Re: How to turn off automatic transitions?
Post by canuck »
You have disabled the "add transitions automatically" but a transitions is still added whenever you add a photo or video on the timeline. Is that correct?
Or, do you simply want to remove the transitions that were added automatically? In this case just switch to the Storyline viewselect a transitions and delete the transition.
If the two clips overlap even slightly, a cross fade is added.
Mark Swanson
So, if I am to understand, a transition of one type or another is always added if there is any overlap at all, and you can't turn that off?
Well, you can turn it off by not overlapping any clips...
pvreditor
processor: Intel i7
ram: 24GB
Hard_Drive_Capacity: 2TB
Post by pvreditor »
Mark Swanson wrote:So, if I am to understand, a transition of one type or another is always added if there is any overlap at all, and you can't turn that off?
Yes, by overlapping clips, you are telling VideoStudio to add a transition. If you do not want a transition, then do not overlap clips.
I recently realized that, by default, VideoStudio is set to use a random transition effect if you overlap files. I got into the preferences and set it so that it will always do a crossfade, which works great for the editing I do. Now I just overlap clips by whatever amount I choose, and it automatically does a nice smooth crossfade.
Bob Kovacs
http://www.bobkovacs.com
Thanks Bob. I had forgotten about the random default as I too first set Crossfade as my preferred transition. I rarely use anything else and when I do it is for a particular effect for that specific video clip e.g. the opening star which introduces a clip focused initially on one of the remaining stars on a Kremlin tower.
