Default colors all messed up
wiggalicious
operating_system: Linux
System_Drive: N/A
processor: AMD Athlon 64 bit
Monitor/Display Make & Model: Benq 2010W
Post by wiggalicious »
Hello dear ASP users,
I don't understand what happened to my copy of ASP. When I navigate through my photos I first see a bland, raw version of my raw file and then a second later it turns all reddish and the highlights are all messed up, like some magician inside my computer turned the highlight slider way up so that I see pink in the clouds and the photo looks darker. It's driving me up the wall!!!!!
I looked at the color profile and I even changed it to the default setting with no effect. I have a calibrated monitor ICC profile and I use that instead. I checked to see if the softproofing button is pressed: it isn't. I also looked at the default settings and chose the default ones. Still no change. I also pushed the reset default files -- no change. Actually there was no resetting to defaults at all. That didn't do anything.
I would really appreciate your help.
Cheers
afx
System_Drive: N/A
Video Card: FirePro 4900
Re: Default colors all messed up
Post by afx »
wiggalicious wrote:I don't understand what happened to my copy of ASP. When I navigate through my photos I first see a bland, raw version of my raw file and then a second later it turns all reddish and the highlights are all messed up, like some magician inside my computer turned the highlight slider way up so that I see pink in the clouds and the photo looks darker. It's driving me up the wall!!!!!
Looks like you saved some defaults that mess up your images.
Leave the image color profile alone. Just use the ICC profiled setting without a specific setting, so it picks up the default.
Yuck. Never ever use a monitor profile for an image.
Did you move the defaults away?
Can you post an XMP for one of the images?
cheers
afx
wiggalicious
System_Drive: N/A
What I meant to say is that I changed the monitor profile to the one I got from dispcalgui after calibration. I actually read it in your ASG ebook -- great book btw!
Anyway, here is the xmp file for one of the images I edited. I also attached it.
Code: Select all
<x:xmpmeta xmlns:x="adobe:ns:meta/" x:xmptk="XMP Core 4.4.0">
 <rdf:RDF xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#">
  <rdf:Description rdf:about=""
    xmlns:dmf="http://www.bibblelabs.com/DigitalMasterFile/1.0/"
    xmlns:dmfversion="http://www.bibblelabs.com/DigitalMasterFileVersion/1.0/"
    xmlns:bset="http://www.bibblelabs.com/BibbleSettings/5.0/"
    xmlns:blay="http://www.bibblelabs.com/BibbleLayers/5.0/"
    xmlns:bopt="http://www.bibblelabs.com/BibbleOpt/5.0/"
   dmf:versionCount="1">
   <dmf:versions>
    <rdf:Seq>
     <rdf:li>
      <rdf:Description
       dmfversion:software="bibble"
       dmfversion:softwareVersion="2008.1"
       dmfversion:versionName="_MG_0001.CR2">
      <dmfversion:settings>
       <rdf:Description
        bset:settingsVersion="66"
        bset:respectsTransform="True"
        bset:curLayer="0">
       <bset:layers>
        <rdf:Seq>
         <rdf:li>
          <rdf:Description
           blay:layerId="0"
           blay:layerPos="0"
           blay:name=""
           blay:enabled="True">
          <blay:options
           bopt:optionchanged="false"
           bopt:hasSettings="false"
           bopt:metaDirty="true"
           bopt:version="8.2"
           bopt:colormode="1"
           bopt:workingspace="2"
           bopt:whiteauto="false"
           bopt:whitetype="8"
           bopt:lwhitetype="8"
           bopt:lmr="1"
           bopt:lmb="1"
           bopt:whitered="65384"
           bopt:whitegreen="65384"
           bopt:whiteblue="65384"
           bopt:whiteowbr="0"
           bopt:whiteowbb="0"
           bopt:autolevel="false"
           bopt:shadowval="0.2"
           bopt:highlightval="0.2"
           bopt:exposureval="0"
           bopt:highlightrecval="0"
           bopt:highlightRange="35"
           bopt:highlightrecthresh="0"
           bopt:blackPoint="0"
           bopt:fillamount="0"
           bopt:fillrange="0.25"
           bopt:autorotate="0"
           bopt:rotateangle="0"
           bopt:sharpensense="6"
           bopt:sharpenrad="0"
           bopt:newsharpen="100"
           bopt:sharpenon="true"
           bopt:bnn_enabled="false"
           bopt:bnn_auto="false"
           bopt:bnn_profile=""
           bopt:bnn_currentprofile=""
           bopt:bnn_turbo="true"
           bopt:bnn_coarse="false"
           bopt:bnn_lstrength="10"
           bopt:bnn_lsmooth="10"
           bopt:bnn_lcontrast="10"
           bopt:bnn_cstrength="10"
           bopt:bnn_csmooth="10"
           bopt:bnn_ccontrast="10"
           bopt:bnn_usmamount="0"
           bopt:bnn_usmradius="1.2"
           bopt:pcenabled="false"
           bopt:pctintmeta="2"
           bopt:red="0"
           bopt:green="0"
           bopt:blue="0"
           bopt:sat="0"
           bopt:cont="0"
           bopt:hue="0"
           bopt:vibe="0"
           bopt:useHSL="false"
           bopt:useHSV="true"
           bopt:invertRegions="false"
           bopt:layerOpacity="1"
           bopt:selective_color=""
           bopt:curveson="false"
           bopt:curves_m_cn="4,1,2,2,2,2"
           bopt:curves_m_cy="4,20,0,65535,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,65535,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,65535,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,65535,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"
           bopt:curves_m_cx="4,20,0,65535,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,65535,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,65535,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,65535,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"
           bopt:curves_m_imid="4,1,1,1,1,1"
           bopt:curves_m_olo="4,1,0,0,0,0"
           bopt:curves_m_ilo="4,1,0,0,0,0"
           bopt:curves_m_ihi="4,1,65535,65535,65535,65535"
           bopt:curves_m_ohi="4,1,65535,65535,65535,65535"
           bopt:kelvin="5656"
           bopt:tint="7"
           bopt:okelvin="5656"
           bopt:otint="7"
           bopt:lkelvin="5656"
           bopt:ltint="7"
           bopt:ckelvin="5656"
           bopt:ctint="7"
           bopt:cropon="false"
           bopt:croplocked="true"
           bopt:cropstyle="0"
           bopt:cropleft="-1"
           bopt:croptop="-1"
           bopt:cropheight="2"
           bopt:cropwidth="3"
           bopt:cropdpi="-1"
           bopt:cropstickydpi="-1"
           bopt:cropstickyx="-1"
           bopt:cropstickyy="-1"
           bopt:cropmenuitem=""
           bopt:croppercent="1"
           bopt:Date="2012-10-11 11:45:44.560"
           bopt:DigitizedDateTime="2012-10-11 11:45:44.560"
           bopt:title=""
           bopt:Priority=""
           bopt:Category=""
           bopt:SupplementalCategory=""
           bopt:creator=""
           bopt:AuthorsPosition=""
           bopt:rights=""
           bopt:Credit=""
           bopt:description=""
           bopt:CaptionWriter=""
           bopt:City=""
           bopt:State=""
           bopt:Country=""
           bopt:CountryCode=""
           bopt:Headline=""
           bopt:Instructions=""
           bopt:TransmissionReference=""
           bopt:Source=""
           bopt:subject=""
           bopt:IntellectualGenre=""
           bopt:CiAdrCity=""
           bopt:CiAdrCtry=""
           bopt:CiAdrExtadr=""
           bopt:CiAdrPcode=""
           bopt:CiAdrRegion=""
           bopt:CiEmailWork=""
           bopt:CiTelWork=""
           bopt:CiUrlWork=""
           bopt:UsageTerms=""
           bopt:Location=""
           bopt:SubjectCode=""
           bopt:Scene=""
           bopt:tag="1"
           bopt:keywordlist=""
           bopt:rating="2"
           bopt:label="0"
           bopt:warpon="false"
           bopt:warpa="0.001185"
           bopt:warpb="0.000505"
           bopt:warpc="0"
           bopt:warpresize="true"
           bopt:warpfocal="60"
           bopt:warpcaon="false"
           bopt:warpcarc="0"
           bopt:warpcaby="0"
           bopt:vignetteon="false"
           bopt:vignetterad="50"
           bopt:vignetteamt="0.5"
           bopt:profilemake="Canon SLR"
           bopt:profilemodel="EOS 60D"
           bopt:profilelens="Canon EF 24-105mm f/4L IS"
           bopt:lens="Canon EF 24-105mm f/4L IS"
           bopt:GPSVersionID="2.0.0.0"
           bopt:GPSLatitude=""
           bopt:GPSLongitude=""
           bopt:GPSAltitudeRef="0"
           bopt:GPSAltitude=""
           bopt:GPSTimeStamp=""
           bopt:GPSSatellites=""
           bopt:GPSStatus="A"
           bopt:GPSMeasureMode=""
           bopt:GPSDateStamp=""
           bopt:GPSMapDatum=""
           bopt:GPSAreaInformation=""
           bopt:GPSProcessingMethod=""
           bopt:bMirrorOn="false"
           bopt:bInvertOn="false"
           bopt:rn_enabled="true"
           bopt:rn_smooth_enabled="false"
           bopt:rn_threshold="0"
           bopt:rn_limit="50"
           bopt:enableInputProfile="false"
           bopt:inputProfile=""
           bopt:AutoLevels.enable="false"
           bopt:AutoLevels.minlevel="0.01"
           bopt:AutoLevels.maxlevel="0.01"
           bopt:ferd.bez_enabled="false"
           bopt:ferd.bez_Early="false"
           bopt:ferd.bez_HCL="false"
           bopt:ferd.bez_opacity="100"
           bopt:ferd.bez_saturation="100"
           bopt:ferd.bez_lighten="0"
           bopt:ferd.bez_lightengamma="0"
           bopt:ferd.bez_midi="50"
           bopt:ferd.bez_sigcontrast="0"
           bopt:ferd.bez_sigmiddle="50"
           bopt:ferd.bez_shadows="10"
           bopt:ferd.bez_lowmids="30"
           bopt:ferd.bez_greys="50"
           bopt:ferd.bez_highmids="70"
           bopt:ferd.bez_highlights="90"
           bopt:ferd.bez_shadows4="20"
           bopt:ferd.bez_lowmids4="40"
           bopt:ferd.bez_highmids4="60"
           bopt:ferd.bez_highlights4="80"
           bopt:ferd.ferd_bez_enabled="false"
           bopt:ferd.ferd_bez_RGB="false"
           bopt:ferd.ferd_bez_BW="false"
           bopt:ferd.ferd_bez_lighten="0"
           bopt:ferd.ferd_bez_lightengamma="0"
           bopt:ferd.ferd_bez_midi="50"
           bopt:ferd.ferd_bez_blak="0"
           bopt:ferd.ferd_bez_sigcontrast="0"
           bopt:ferd.ferd_bez_sigmiddle="0.5"
           bopt:ferd.ferd_bez_contrast="0"
           bopt:ferd.ferd_bez_centre="0"
           bopt:ferd.ferd_bez_shadows="10"
           bopt:ferd.ferd_bez_lowmids="30"
           bopt:ferd.ferd_bez_greys="50"
           bopt:ferd.ferd_bez_highmids="70"
           bopt:ferd.ferd_bez_highlights="90"
           bopt:ferd.ferd_bez_shadows4="20"
           bopt:ferd.ferd_bez_lowmids4="40"
           bopt:ferd.ferd_bez_highmids4="60"
           bopt:ferd.ferd_bez_highlights4="80"
           bopt:rbarnes.gradfilterresetopt="false"
           bopt:rbarnes.gradfilter_enabled="false"
           bopt:rbarnes.gradfilter_white="false"
           bopt:rbarnes.gradfilter_brighten="false"
           bopt:rbarnes.gradfilter_strength="20"
           bopt:rbarnes.gradfilter_edge="20"
           bopt:rbarnes.gradfilter_offset="50"
           bopt:rbarnes.gradfilter_rotation="0"
           bopt:rbarnes.gradfilter_enabled_f1="true"
           bopt:rbarnes.gradfilter_color="0"
           bopt:rbarnes.gradfilter_enabled_f2="false"
           bopt:rbarnes.gradfilter_brighten_f2="false"
           bopt:rbarnes.gradfilter_strength_f2="20"
           bopt:rbarnes.gradfilter_edge_f2="20"
           bopt:rbarnes.gradfilter_offset_f2="50"
           bopt:rbarnes.gradfilter_rotation_f2="0"
           bopt:rbarnes.gradfilter_color_f2="0"
           bopt:rbarnes.gradfilter_enabled_f3="false"
           bopt:rbarnes.gradfilter_brighten_f3="false"
           bopt:rbarnes.gradfilter_strength_f3="20"
           bopt:rbarnes.gradfilter_edge_f3="20"
           bopt:rbarnes.gradfilter_offset_f3="50"
           bopt:rbarnes.gradfilter_rotation_f3="0"
           bopt:rbarnes.gradfilter_color_f3="0"
           bopt:LabTools.enable="false"
           bopt:LabTools.contrast="0"
           bopt:LabTools.lightness="0"
           bopt:LabTools.saturation="0"
           bopt:Nuance.Nuance_enabled="false"
           bopt:Nuance.Nuance_settings=""
           bopt:Nuance.Nuance_map="false"
           bopt:Vigne_kb.kbv_enabled="false"
           bopt:Vigne_kb.kbv_size="50"
           bopt:Vigne_kb.kbv_strength="-10"
           bopt:Vigne_kb.kbv_ccol="true"
           bopt:Vigne_kb.kbv_falloff="1"
           bopt:Vigne_kb.kbv_shape="0"
           bopt:Vigne_kb.kbv_horzcenter="50"
           bopt:Vigne_kb.kbv_vertcenter="50"
           bopt:Vigne_kb.kbv_factor="0"
           bopt:Vigne_kb.kbv_trans="50"
           bopt:Vigne_kb.kbv_adjustcrop="true"
           bopt:Vigne_kb.kbv_colenabled="false"
           bopt:Vigne_kb.kbv_col="-10"
           bopt:Vigne_kb.kbv_preview="false"
           bopt:Vigne_kb.kbv_desat="false"
           bopt:Vigne_kb.kbv_desaturate="0"
           bopt:WaveletDenoise2.bSphWaveletDenoiseon="false"
           bopt:WaveletDenoise2.bSphWaveletDenoiseThresL="0"
           bopt:WaveletDenoise2.bSphWaveletDenoiseLowL="0"
           bopt:WaveletDenoise2.bSphWaveletDenoiseThresC="0"
           bopt:WaveletDenoise2.bSphWaveletDenoiseLowC="0"
           bopt:WaveletDenoise2.bSphWaveletDenoiseDePepper="false"
           bopt:WaveletDenoise2.bSphWaveletDenoiseShowEdge="false"
           bopt:WaveletSharpen2.bSphWaveletUsmon="false"
           bopt:WaveletSharpen2.bSphWaveletUsmRadius="50"
           bopt:WaveletSharpen2.bSphWaveletUsmAmount="100"
           bopt:WaveletSharpen2.bSphWaveletUsmThreshold="0"
           bopt:WaveletSharpen2.bSphWaveletUsmClarity="false"
           bopt:WaveletSharpen2.bSphWaveletLLenable="false"
           bopt:WaveletSharpen2.bSphWaveletLLStrength="30"
           bopt:WaveletSharpen2.bSphWaveletLLiter="3"
           bopt:WaveletSharpen2.bSphWaveletMCStrength="0"
           bopt:WaveletSharpen2.bSphWaveleton="false"
           bopt:WaveletSharpen2.bSphWaveletAmount="50"
           bopt:WaveletSharpen2.bSphWaveletRadius="0.5"
           bopt:WaveletSharpen2.bSphWaveletSharpenDePepper="false"
           bopt:WaveletSharpen2.bSphWaveletEdge="100"
           bopt:WaveletSharpen2.bSphWaveletSharpenClarity="false"
           bopt:WaveletSharpen2.bSphWaveleton2="false"
           bopt:WaveletSharpen2.bSphWaveletAmount2="50"
           bopt:WaveletSharpen2.bSphWaveletRadius2="2"
           bopt:WaveletSharpen2.bSphWaveletSharpenDePepper2="false"
           bopt:WaveletSharpen2.bSphWaveletEdge2="100"
           bopt:WaveletSharpen2.bSphWaveletSharpenClarity2="false"
           bopt:zChannelMixerGroup.zcmEnable="false"
           bopt:zChannelMixerGroup.zcmbw="false"
           bopt:zChannelMixerGroup.zcmbwa="false"
           bopt:zChannelMixerGroup.zcmlockbw="false"
           bopt:zChannelMixerGroup.zcmlockcolor="false"
           bopt:zChannelMixerGroup.zcmrr="100"
           bopt:zChannelMixerGroup.zcmrg="0"
           bopt:zChannelMixerGroup.zcmrb="0"
           bopt:zChannelMixerGroup.zcmgr="0"
           bopt:zChannelMixerGroup.zcmgg="100"
           bopt:zChannelMixerGroup.zcmgb="0"
           bopt:zChannelMixerGroup.zcmbr="0"
           bopt:zChannelMixerGroup.zcmbg="0"
           bopt:zChannelMixerGroup.zcmbb="100"
           bopt:blplug.bbwenabled="false"
           bopt:blplug.bbwspotA="false"
           bopt:blplug.bbwspotB="false"
           bopt:blplug.bbwhueA="0"
           bopt:blplug.bbwfuzzyA="25"
           bopt:blplug.bbwcolorA="0"
           bopt:blplug.bbwhueB="200"
           bopt:blplug.bbwcolorB="200"
           bopt:blplug.bbwfuzzyB="25"
           bopt:blplug.bbwmode="0"
           bopt:Equalizer_kb.kbs_enabled="false"
           bopt:Equalizer_kb.kbs_bw="false"
           bopt:Equalizer_kb.kbs_redlum="0"
           bopt:Equalizer_kb.kbs_yellowlum="0"
           bopt:Equalizer_kb.kbs_orangelum="0"
           bopt:Equalizer_kb.kbs_greenlum="0"
           bopt:Equalizer_kb.kbs_cyanlum="0"
           bopt:Equalizer_kb.kbs_bluelum="0"
           bopt:Equalizer_kb.kbs_magentalum="0"
           bopt:Equalizer_kb.kbs_redhue="0"
           bopt:Equalizer_kb.kbs_yellowhue="0"
           bopt:Equalizer_kb.kbs_orangehue="0"
           bopt:Equalizer_kb.kbs_greenhue="0"
           bopt:Equalizer_kb.kbs_cyanhue="0"
           bopt:Equalizer_kb.kbs_bluehue="0"
           bopt:Equalizer_kb.kbs_magentahue="0"
           bopt:Equalizer_kb.kbs_redsat="0"
           bopt:Equalizer_kb.kbs_yellowsat="0"
           bopt:Equalizer_kb.kbs_orangesat="0"
           bopt:Equalizer_kb.kbs_greensat="0"
           bopt:Equalizer_kb.kbs_cyansat="0"
           bopt:Equalizer_kb.kbs_bluesat="0"
           bopt:Equalizer_kb.kbs_magentasat="0"
           bopt:Equalizer_kb.kbs_redvib="0"
           bopt:Equalizer_kb.kbs_yellowvib="0"
           bopt:Equalizer_kb.kbs_orangevib="0"
           bopt:Equalizer_kb.kbs_greenvib="0"
           bopt:Equalizer_kb.kbs_cyanvib="0"
           bopt:Equalizer_kb.kbs_bluevib="0"
           bopt:Equalizer_kb.kbs_magentavib="0"
           bopt:Nostalgia.Nostalgia_enabled="false"
           bopt:Nostalgia.Nostalgia_filter="BW: Red 23A"
           bopt:Nostalgia.Nostalgia_film="BN: Agfa Agfapan 25 Refinal 6min"
           bopt:Nostalgia.Nostalgia_paper="BN: Agfa MultiContrast Premium Filter 0"
           bopt:Nostalgia.Nostalgia_filmid="16018434"
           bopt:Nostalgia.Nostalgia_paperid="62745044"
           bopt:Nostalgia.Nostalgia_dr="9"
           bopt:Nostalgia.Nostalgia_exposure="0"
           bopt:Nostalgia.Nostalgia_darkroom="0"
           bopt:Nostalgia.Nostalgia_dmax="5"
           bopt:Nostalgia.Nostalgia_fred="0"
           bopt:Nostalgia.Nostalgia_fgreen="0"
           bopt:Nostalgia.Nostalgia_fblue="0"
           bopt:Nostalgia.Nostalgia_flatitude="0"
           bopt:Nostalgia.Nostalgia_platitude="0"
           bopt:Nostalgia.Nostalgia_rgb="true"
           bopt:Nostalgia.Nostalgia_print="true"
           bopt:Nostalgia.Nostalgia_indicator="false"/>
          </rdf:Description>
         </rdf:li>
        </rdf:Seq>
       </bset:layers>
       </rdf:Description>
      </dmfversion:settings>
      </rdf:Description>
     </rdf:li>
    </rdf:Seq>
   </dmf:versions>
  </rdf:Description>
 </rdf:RDF>
</x:xmpmeta>
_MG_0001.CR2.xmp
(15.7 KiB) Downloaded 182 times
afx
System_Drive: N/A
Post by afx »
Drat, nothing in there jumps at me as a problem ;-(
No idea...
cheers
afx
neilmwhite
Post by neilmwhite »
Have you resolved your problem yet?
I don't think it has anything to do with color profiles. I suspect you have switched on the clipped higlight warning by mistake. Bottom right hand of screen there is a yellow triangle which is a toggle switch for the highlight warning. Try clicking that and see if your nasty colours in the highlight areas disappears.
Neil
