Place an image in text
Rosemary
Post by Rosemary »
Could someone please suggest a tutoral on how to place an image in text using PSPx4?
I am trying to place a flag to appear in the text "Vancouver" I am not all that proficient with PaintShop
Thanks in advance,
Rosemary
Kathy_9
Hard_Drive_Capacity: 2TB
Re: Place an image in text
Post by Kathy_9 »
I can think of a couple options.
Option 1:
  • Open an image of the flag you want to use
    Click the text tool
    On the text toolbar set "Create As" to" Selection"
    Type your text (the word Vancouver)
This will put your text on a new layer and you can delete the background (flag image) layer.
Option 2:
    Open a new image where you will put your text
    Click on the Background swatch on the Materials Palette
    Click on the Pattern tab
    Find your flag image, adjust the scale and select it
    Type your text
LindaSue
motherboard: Gigabyte
processor: 2.71GHz AMD Athlon II X2 215 processor
ram: 3 GB
Video Card: ATI Radeon HD 4350
sound_card: Realtek AC97 Audio [onboard]
Hard_Drive_Capacity: 1320 GB
Monitor/Display Make & Model: Asus MX279 HDMI 27-inch
Corel programs: Paint Shop Pro X2, X4, X6
Post by LindaSue »
I never thought of actually typing the text with a pattern. Great idea. However, it only works with either Vector text or Floating text, not with Selection. With Selection all you get is a selection marquee.
Using Paint Shop Pro versions 5, 6, 7, 8, 9, 12, 14, 16
Rosemary
Post by Rosemary »
Thank you Kathy for your tutorial and LindaSue for your suggestion. Is it possible to position the text over a certain area of the flag or am I asking too much? I saw the original effect in a slideshow but it was done in Photoshop
http://www.photoshopessentials.com/phot ... e-in-text/
When I try I am getting the first letters all in black with a few coloured in the centre of the flag.
Further help required I am afraid
Rosemary
LindaSue
ram: 3 GB
Post by LindaSue »
Probably the easiest way would be to use Selection text as Kathy suggested. First, promote the flag image to a raster layer then create your text selection directly on the flag image. Move the selection marquee so that it's positioned where you want it over the flag. To do this, right-click using the Move tool to move the selection marquee. Invert the selection (Selections > Invert) and press the Delete key to remove that excess background from the flag image.
LindaSue
ram: 3 GB
Post by LindaSue »
By the way, I took a quick look at that Photoshop tutorial and it's way more complicated to do with Photoshop than it is to do the same thing in PSP.
LindaSue
ram: 3 GB
Post by LindaSue »
Here's an example using the method I posted. I duplicated the flower photo layer just so that you could see how it looked before I cut out the text from it.
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
If it helps, and you're a tinkerer, you don't have to create the text as a selection. You can create the text as a normal vector. Turn off the fill and use a light border so you can picture where it would be. This allows you to constantly move, edit, rewrite, the text until you have an option you consider perfect.
Turn the fill for the text back on for this next step. If you don't the selection won't work quite right.
Then with the text selected go to the menu and select Selections -> From Vector Object.
This will create a selection in the shape of your text. Hide the text layer you can now create a mask or delete the areas you don't want.
photodrawken
ram: 16Gb
Hard_Drive_Capacity: 324Gb
Post by photodrawken »
LindaSue wrote:By the way, I took a quick look at that Photoshop tutorial and it's way more complicated to do with Photoshop than it is to do the same thing in PSP.
Actually, it's not that more complicated; and the beauty and power of the PS method is that the text mask remains as text and can be re-worded, re-sized, re-positioned, etc., and the image fill simply accommodates those changes.
Coming from Photoshop Elements as I am, the most important feature I miss in PSP is the ability to use any vector object (including text) as a "clipping mask". It's hard to overstate the power and flexibility of that method, which retains the sharp edges of the masking vector shape when re-sized, etc.
Ken
Rosemary
Post by Rosemary »
Thank you very much everyone. I appreciate the help and the illustrations. I am going to have fun with this one. I want to use the end result as title slides for slideshows.
Rosemary
LindaSue
ram: 3 GB
Post by LindaSue »
Of course there are more complicated ways to do this with PSP as well. You could make copies of the text layers, create a mask, get selections from the mask or from vector text and save to an alpha channel for future editing, etc. Rosemary said she was a PSP newbie so I didn't want to make it too complicated for her.
