Question on After Shot Pro
Moldmaker
operating_system: Linux
System_Drive: N/A
motherboard: ASRock X58
processor: Intel i7 950 3.07 GHz
ram: 6GB
Video Card: NVidia GTX 580
sound_card: Onboard
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: Samsung 2233 RZ
Post by Moldmaker »
Hi everybody,
I have a Nikon DSLR and I am interested in using ASP. I have one question that I did not find an answer for:
Does ASP support information that the camera writes in the RAW files, such as lens distortion correction, light falloff correction or Nikon's "picture control" settings?
I understand that ASP has its own lens correction database. Does this mean that I should switch off the lens correction in the camera, or is this information ignored completely by ASP?
Thank you for helping.
Mm.
teknisyan
processor: Intel Corel i5
ram: 4 GB
sound_card: Realtek HD Audio
Hard_Drive_Capacity: 500 GB
Re: Question on After Shot Pro
Post by teknisyan »
I'm not a ASP power user and I may not be able to answer all your question but I bet you'll the answer when you use the program, so I suggest that you download the trial version and see for your self.
You can go to http://pnoy.me/coreltrials to download the trial version.
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
Denis de Gannes
motherboard: Gigabyte- G31MX-S2
processor: Intel Core Quad CPU Q6700 2.66 GHz
ram: 4GB
Video Card: On Motherboard
sound_card: nk000
Hard_Drive_Capacity: 1820 GB
Monitor/Display Make & Model: AOC 2216Sw
Post by Denis de Gannes »
ASP does not automatically make lens corrections, which are written to the raw files,from my Panasonic G3 (micro 4/3rds). This is a know requirement for micro4/3rds cameras but I am not aware of a similar requirement for Nikon DSLR cameras.
It is my understanding that, Lens correction features in ASP, Lightroom, Capture One, DxO etc are created to correct for limitations in lens design, and these need to be designed specific to lens/camera body.
The corrections for my G3 are made automatically when processed in Lightroom, Capture One Express and Qimage Ultimate to name a few of the other raw processing software I use.
Denis
Camera: Oly E300 & E510; ZD & OM Lenses; Panasonic G3
Software: PSP x4; Corel Video Studio Pro X3; PS CS6; SilkyPix 4; ASP 1; LR 5.4; Capture One Ex 7; Qimage Ultimate; VueScan.
Trucks
System_Drive: N/A
motherboard: 64bit
processor: quad
ram: 3GB
Video Card: Nvidia
sound_card: onboard
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: Eizo S2243 W
Post by Trucks »
as far as i know ASP or other Products can`t use this informations. The most manufacturer don`t release this informations and they don`t use Open Raw. http://www.openraw.org/
Automatic Lens Correction: Maybe you can try it and write something in here ;-)
Regards
Trucks
ferdinand-paris
motherboard: GA-X58A-UD3R
processor: 3.20 gigahertz Intel Core i7 960
ram: 4Gb
Video Card: NVIDIA GeForce 7300 GS
sound_card: Realtek High Definition Audio on-board
Hard_Drive_Capacity: 2500 Gb
Monitor/Display Make & Model: Eizo CG222W
Post by ferdinand-paris »
Moldmaker
System_Drive: N/A
ram: 6GB
sound_card: Onboard
Post by Moldmaker »
Hi everybody,
Thanks for all the answers.
So I downloaded the trial version which installs and runs smoothly under Linux (very nice!). Just to find out that my camera is not supported yet. It is a Nikon D600 and I was very sure that the NEF file format is identical to the D800, but it isn't. Too bad. And the newest ASP Beta does not support it either.
Well, at least I was able to test ASP with some color slide scans in the TIFF format, and I liked the software instantly, and it is working fast!
Maybe I have to wait until the D600 will be supported. Question is, how do I test ASP again because by then the test period might be expired ...
Mm.
Trucks
System_Drive: N/A
motherboard: 64bit
processor: quad
ram: 3GB
Video Card: Nvidia
sound_card: onboard
Post by Trucks »
In the "good" old ASP Times it was possible to get a trial extension if you wrote a mail. If Corel goes the same way?
Regards
Trucks
greerd
System_Drive: Z
processor: Intel i7 920
ram: 12 GiB
Video Card: nVidia GeForce 260
sound_card: Onboard
Hard_Drive_Capacity: 5 TB
Monitor/Display Make & Model: Dell UltraSharp U2410
Post by greerd »
Moldmaker wrote:Hi everybody,
Mm.
I think that if the camera name in the exif data is not supported, then your out of luck even if its the identical sensor. A work around is to change the camera name in the exif file. Worth a try and will let you give play with the software.
Moldmaker
System_Drive: N/A
ram: 6GB
sound_card: Onboard
Post by Moldmaker »
Thank you all.
Asking for a longer test period is an option - I might come back to that idea.
I was unable to fool the software with another camera name in the NEF's exif data, but nevertheless I have more than 8000 slide scans in the TIFF format to play with.
The "Noise Ninja" is quite impressive. I understand that there is an even more sophisticated version if you pay for it. I already like this one, though.
Mm.
