Hi Trevor,
Considering the fact that you live in England and I live in Canada, I don't believe that sending you the .ISO file will work.
Obviously, the reason being is that I formated the final DVD files in NTSC, and you are using the PAL format over there.
However, let me try to explain what the final result is that I have accomplished with this program "MPEG Video Wizard DVD
5.0.1.105 (09/2012)" made by "Womble Multimedia, Inc.".
I created a first play "Main Menu", and on this menu are the following clickable menu titles 1) "Play Movie", 2) "Chapters", and
3) Special Features". I also have the Main Title of the DVD stationed above a moving video in a frame with music playing in the
background.
The following is what happens when I put the DVD into either a Blu-ray or normal DVD player.
The DVD starts with the main DVD menu showing up right away, then you can do the following.
1) Click on Play Movie on the Main Menu and when the Main Movie finishes, it will return to the main DVD menu. It does not
continue to play any of the Special Features on the disc (like what happens in "Corel VideoStudio Pro X5 Ultimate", their major flaw).
2) Click on Chapters on the Main Menu, and the Chapters Menu comes up. I can click on any chapter and when that particular
chapter is finished playing it will return to the chapters menu. It does not continue to play to the end of the main movie or any of the
Special Features on the disc after the main movie (like what happens in "Corel VideoStudio Pro X5 Ultimate", their major flaw).
I set it up this way on purpose just to see how much control I can have with the DVD menu. I realize that the majority of DVD's
will continue to the end of the movie. However, in the case of a home made movie each chapter might represent a different part of a
city trip, country trip, or different subject, etc., and so in that case this feature control would be a very handy feature control to have.
3) Click on Special Features on the Main Menu and the Special Features Menu comes up. I have two Special Features available
to choose from on the Special Features Menu page (I could have as many as I would like, I just used two for the testing).
I can click on any of the Special Features on the Special Features Menu page and when that particular Special Feature is
finished playing it will return to the Special Features Menu page.
It does not continue to play to the end of the second, third or fourth, etc., Special Feature on the disc (like what happens in
I can return to the Main Menu on the DVD at any time from any Menu just by clicking on the Main Menu control button on the
DVD (which is on any menu's you make on the DVD, with the exception of the first play Main Menu of course).
All of the menu's have a moving video in a frame with music playing in the background. Chapters and Special Features
Menu's have many moving video's in a frame with music playing in the background.
Meaning that if you have ten Chapters and ten Special Features, each Chapter and each Special Feature will have a moving
You can set it up so that you can either click on the moving video in a frame to start playing the video or you can set it up so
that you can click on the title of that particular Chapter or Special Feature to start playing the video. Each moving video in a
frame with music playing in the background has a title of that frame underneath it (which you can call it whatever you would
like to title it).
I hope this explains for you Trevor and others of course, just how great this program is and what it can accomplish for all of
you out there who want a real professional looking Hollywood style DVD Menu on their final project DVD's.
Final Note:
It is a real shame that "Corel VideoStudio Pro X5 Ultimate", has this major flaw and up to this point they have not done anything
to fix this major flaw in their program.
In other words, they have not tried to fix this issue so that when you want a real professional looking Hollywood style DVD Menu
on your final project DVD, to make it work just like "MPEG Video Wizard DVD 5.0.1.105 (09/2012)" made by "Womble Multimedia, Inc."
has done.
Again, this program can be found (downloaded) at the companies website "
http://www.womble.com/download/dvd5.exe ", you can use
a FREE trial full version for 30 days to check it out yourself. It is an amazing program and works just like it says it should.
By the way Trevor, .ufo files can be opened with either note pad or word pad, you just have to remember to click "Save", and never
click "Save As". By clicking just "Save" after making changes, it will continue to save the .ufo file as a .ufo file. If you click "Save As" you
do not get the choice to save it as a .ufo file.
The problem or issue that needs to be solved by either the Corel Corporation or one of us is knowing which .ufo file needs to be
used, and what commands need to be changed within that particular .ufo file. That is the issue that needs to be solved to make
"Corel VideoStudio Pro X5 Ultimate" work just like "MPEG Video Wizard DVD 5.0.1.105 (09/2012)" made by "Womble Multimedia, Inc.".
Take Care & Stay Safe,
Ross aka CANADA
