Combine files with different properties
dmz
motherboard: ASUS ROG Strix Z390-I
processor: Intel Gen 9 i7 9700K
ram: 32GB
Video Card: mobo onboard
sound_card: mobo onboard
Hard_Drive_Capacity: 6TB
Corel programs: VS 2020
Post by dmz »
Greetings,
I have three video files. Each has a different frames per second. Each has a different audio format. Each has different bit rates. One has upper field first, one has lower field first.
Im assuming that I cannot simply drop the three files into the time line and produce one output file (obviously with the lowest bit rate and fps).
Do I assume correct? and if so, how does one combine files with vastly different properties to produce one output file?
David
Re: Combine files with different properties
Hi David
Frame Rate—frames per second
Changing this from 30 to 25 will result in removing 25 frames, 1 in 5
Playback may show jerky especially when panning.
You are in Austraila using Pal at 25 fps, do a little test.
Using the libries sample video V10, drag to the timeline the film runs from bottom to top.
Notice the properties are 29 fps NTSC.
Share Create Video File DVD will convert the file to 25 fps.
Play each clip from the library to compare.
Interlacing
Upper and Lower fields, where possible you should try to keep the original field order.
Changing the field order may show as jagged lines within the video.
You should be able to convert to Frame Based which is used for internet and some HD video types.
If you have to change things, change the shortest clip.
Data Rate or Bit Rate
Not a problem and can be altered usually to create a smaller file size allowing it to fit to disc.
Audio
Should not be a problem.
David can you tell us what you are trying to create, a video for the internet or a DVD, or are you working with HD?
Can you provide the properties of these video files and maybe their duration?
dmz
ram: 32GB
Post by dmz »
OK - One video has these properties:
General
Complete name : F:\Video\source files\Latest Lembasts DVD 2012-05-09\00-Intro.mpg
Format : MPEG-PS
File size : 26.0 MiB
Duration : 53s 440ms
Overall bit rate mode : Variable
Overall bit rate : 4 081 Kbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=12
Bit rate mode : Variable
Bit rate : 3 808 Kbps
Maximum bit rate : 7 500 Kbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.367
Stream size : 24.3 MiB (93%)
Color primaries : BT.601 PAL
Transfer characteristics : BT.470 System B, BT.470 System G
Matrix coefficients : BT.601
Audio
ID : 189 (0xBD)-128 (0x80)
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Muxing mode : DVD-Video
Duration : 53s 248ms
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Another video has these properties:
General
Complete name : F:\Video\source files\Latest Lembasts DVD 2012-05-09\Lembasts raw files from dec 2011\raw from main camera\01.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 1.08 GiB
Duration : 31mn 34s
Overall bit rate : 4 881 Kbps
Encoded date : UTC 2011-12-16 21:16:00
Tagged date : UTC 2011-12-16 21:16:44
Video
Format : MPEG-4 Visual
Format profile : Simple@L1
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : 20
Duration : 31mn 34s
Bit rate : 4 685 Kbps
Width : 1 440 pixels
Height : 1 080 pixels
Original display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.101
Stream size : 1.03 GiB (96%)
Language : English
Encoded date : UTC 2011-12-16 21:15:24
Color primaries : BT.709
Transfer characteristics : BT.601
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 31mn 34s
Source duration : 31mn 34s
Bit rate : 75.1 Kbps
Nominal bit rate : 64.0 Kbps
Sampling rate : 44.1 KHz
Stream size : 17.0 MiB (2%)
Source stream size : 17.0 MiB (2%)
Language : English
And another video has these properties:
General
Complete name : F:\Video\source files\Latest Lembasts DVD 2012-05-09\Lembasts raw files from dec 2011\raw from other cameras\DCIM\100CANON\MVI_1564.MOV
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt
File size : 250 MiB
Duration : 44s 44ms
Overall bit rate : 47.7 Mbps
Encoded date : UTC 2011-12-03 10:10:28
Tagged date : UTC 2011-12-03 10:10:28
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Baseline@L5.0
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=12
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 44s 44ms
Bit rate : 46.1 Mbps
Width : 1 920 pixels
Original height : 1 088 pixels
Original display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.928
Stream size : 242 MiB (97%)
Language : English
Transfer characteristics : BT.709
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : sowt
Duration : 44s 44ms
Bit rate : 1 536 Kbps
Bit depth : 16 bits
Stream size : 8.06 MiB (3%)
Language : English
And the last one has these properties:
General
Complete name : F:\Video\source files\Latest Lembasts DVD 2012-05-09\Lembasts raw files from dec 2011\raw from other cameras\MVI_0012-HDV 1080i50-MPEG-4 .mp4
Format : MPEG-4
Codec ID : mp42
File size : 76.2 MiB
Duration : 2mn 10s
Overall bit rate : 4 906 Kbps
Encoded date : UTC 2011-12-16 23:27:46
Tagged date : UTC 2011-12-16 23:27:49
Video
Codec ID : 20
Duration : 2mn 10s
Bit rate : 4 725 Kbps
Color space : YUV
Bit depth : 8 bits
Stream size : 73.4 MiB (96%)
Language : English
Encoded date : UTC 2011-12-16 23:27:44
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 2mn 10s
Source duration : 2mn 10s
Bit rate : 58.4 Kbps
Stream size : 928 KiB (1%)
Source stream size : 928 KiB (1%)
Language : English
I think two of the above are the same...
Anyway they are videos of our band from three different cameras and I want to do a multi angle sort of thing combining bits and pieces.
Cheers
David z
A lot of info, you can view the video files properties via Video Studio, simply right click any clip and select properties.?
I asked “David can you tell us what you are trying to create, a video for the internet or a DVD”
Ok
The first appears to be standard Pal DVD 16:9 25fps, Interlaced Upper Field First.
If you are intending to burn a disc then these properties are suitable for burning a DVD. These are the settings you should be using for your final video file.
The second is Mpeg4 progressive using NTSC standards
Widescreen 16:9 1440 x 1080 at 29.97fps
The third is Quicktime Mov AVCHD 23.976fps progressive.
The only issue is the frame rates 25fps, 23.97fps and 29.97fps
Combining these videos may/will show some playback issues.
One of the three will be the main video, ideally the longest would be used for the final video retaining those properties.
For a DVD then the first should be used.
So are you trying to make a DVD disc?
Combining these will show some playback issues, whether these are noticeable or acceptable really depends on the video content, if the video was quite static with little panning then the effect will be minimal.
Beauty is in the eye of the beholder………..give it a go.
Once you have the project constructed you can create different video files to see which is best, for the internet that is, for a Disc you are stuck with the first type, Pal DVD
