The plugin Zsoften "seems to work" under ASP.
However, during the output stage it is ignored. JPEG full Size or JPEG Proof does not matter.
I have reported this as a bug using the suggested medium.
This is just to inform the user community and the plugin developer.
SOLVED - ZSoften does not effect the output on 1.1.0.30
bcelasun
- motherboard: ASUS CM6830
- processor: Intel Core i5-3450
- Monitor/Display Make & Model: Dell 2209WA
Hobgoblin
- System_Drive: N/A
Re: ZSoften does not effect the output on 1.1.0.30
Working fine here for me.bcelasun wrote:The plugin Zsoften "seems to work" under ASP.
Ensure that you have the latest versions of ZFrame and ZText installed. There is an interaction between the codes of these plugins and ZSoften.
See tintin's post ..http://forum.corel.com/EN/viewtopic.php ... 59#p257959
R.
PC(s): Linux Mint 18
Laptop:Linux Mint 18
Photo Software:
Darktable 2.0.4 http://www.darktable.org/
AfterShot 2 Pro
Cameras: Pentax: K-5 & Olympus TG-4
Photo Software:
AfterShot 2 Pro
bcelasun
Hobgoblin,
Thank you!
You mean, one should update ZText end ZShadow.
As you said, everything is just fine now
Thank you!
