Typewriter not working with beta 1.1.0.30
dFlyer
- System_Drive: N/A
Typewriter is no longer working with ASP beta 1.1.0.30 with Ubuntu 12.10. The Signature will show on the photo but not on the saved copy.
Thanks.
Gary Garibaldi
Linux since 96
Sony a700
Sony a100
Gary Garibaldi
Linux since 96
Sony a700
Sony a100
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Re: Typewriter not working with beta 1.1.0.30
It is a libc issue on Linux.
And it looks like sadman is not really motivated, so I fear you need to switch to zText or external scripts ;-(
I will probably star using an external imagemagick script again, for several reasons...
Apart from typewriter support, I am considering scaling issues.
Bernd correctly pointed out that all the text applied to an image is applied pre-scaling in the queue. If you do it in external script on the final size, the font looks nicer.
cheers
afx
cheers
afx
dFlyer
- System_Drive: N/A
Thanks, switching to zText.
Thanks.
Gary Garibaldi
Linux since 96
Sony a700
Sony a100
Gary Garibaldi
Linux since 96
Sony a700
Sony a100
tundraquad
- System_Drive: N/A
I also ended up switching back to zText a couple of month ago. After going back & forth between both several times, I now keep the presets for both. Although I miss TypeWritter, I must admit that tin.tin does a good job keeping zText updated. The fact that now you can have a second line of text is a big improvement. (Thanks tin.tin !)
So long,
So long,
