Renaming and numbers
pgman
operating_system: Linux
System_Drive: N/A
Post by pgman »
I have files: img_1234.cr2, img_1235.cr2 and so on. I'd like to select a bunch of them and have them renamed as:
img_1234.cr2 becomes granville-island-20121027-1234.cr2
img_1235.cr2 becomes granville-island-20121027-1235.cr2
img_1236.cr2 becomes granville-island-20121027-1236.cr2
I'd like to only type "granville-island-20121027-" but I want to keep the 1234, 1235, 1236...
Is there a way?
Thank you in advance
sauron
System_Drive: X
motherboard: Asus P5E WS Pro
processor: Intel Core2 Duo E6850
ram: 4GB
Video Card: ATI Radeon X850XT
sound_card: on board
Hard_Drive_Capacity: 5Tb
Monitor/Display Make & Model: NEC Multisync 2190UXi
Re: Renaming and numbers
Post by sauron »
Code: Select all
exiftool '-filename<granville-island_${DateTimeOriginal}_${ImageNumber}.%e' -d "%Y%m%d" .
Should do what you want... That means you won't need to type anything different - the same command will work for pretty much anything. It relies on your camera placing the number in the "ImageNumber" exif tag - some cameras use "FileNumber" instead, so you may need to vary that bit.
ogrizzo
operating_system: Mac
System_Drive: Q
processor: 2.8 Ghz Intel Core i7
ram: 8 GB
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: Integrated Apple iMac 27"
Post by ogrizzo »
pgman wrote:Hi,
Is there a way?
Yes, it is possible, and you don't even need to type the date: http://product.corel.com/help/AfterShot ... index.html
[jobname]-[date]-[onum].[oext] should do the trick.
Of course, always back up your files before making any experiment and thoroughly check everything is fine before going on.
Ottavio
afx
System_Drive: N/A
Video Card: FirePro 4900
Post by afx »
But if the OP really wants the date without the dashes, then "[year][month][day]" is needed instead of [date].
I personally think [10dateiso] is safer than [date]. If I remember correctly [date] depends on the settings in the preferences...
cheers
afx
pgman
System_Drive: N/A
Post by pgman »
Perfect! Thank you
