More instant projects
Ken Veal
motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
processor: 360 gigahertz Intel Core i9 900K
ram: 32 GB
Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
Hard_Drive_Capacity: 1250GB SSD
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Post by Ken Veal »
Can more instant projects be obtained, free or otherwise, to use in VSX5.If so, where from and how are they imported into VS.
(my previous version was 11+)..Ken
Re: More instant projects
Post by BrianCee »
you can download a lot for free here :- http://www.photovideolife.com/
There are also many many more under the 'Do More' tab in the Corel Guide Kenneth - you download them and they install by themselves.
see below:
Hi Ken
When I view my library I see 31 Instant projects available, how many do you see.?
From the Do More that Brian mentioned there are approx 80 Instant Projects available for download.
Some of the downloads are DVD Menu Templates.
Be aware there was a problem installing some of these, raised by a member of the forum some time ago.
http://forum.corel.com/EN/viewtopic.php ... sp#p254375
As there are 80 installing all to the library may not be what you want.
When I download the file it is automatically installed a folder to the VSPTemplate folder, however only installs to the library after re-starting Video Studio.
I moved the Folder to another location. Running Video Studio kept my library clear.
I was however able to view the Instant project within Video Studio by opening the associated VSP.
When I found one i liked I simply moved the folder to the VSPTemplate which ultimately installed to my library.
Ken Veal
ram: 32 GB
Post by Ken Veal »
I have 31too.Will I avoid problems if I do not download the templates as I am only interested in instant projects at present.I take it I will easily be able to see the difference.Would downloading the lot slow things down or cause any other problem?
Post by BrianCee »
they are known by Corel as Instant project templates - it is not two different things - a template and an instant project are one and the same thing.
the other items in the do more downloads are DVD menus - they are reasonably well identified - you only need to download instant project templates which look interesting to you - I see no point in downloading hundreds of them that you may never use.
Hi Ken
You only download one at a time, I do not think there is an option to select "all"
Once you have downloaded one template the download option will be unavailable and be marked as "Installed"
That is you can only download once.
Unfortunately there is no options to view the effects without downloading, but you can avoid filling the library by following my instructions given earlier.
Then you can view each till you find a suitable candidate, then add that to the library.
