zText on beta 1.1.028
Re: zText on beta 1.1.028
Thanks TinTin,
This is a very good news.
By the way, since sadman is abandoned the typewriter plugin. Would you be able to add one more set of text input so that we can have one text for the signature and one text for the title please?
Thanks a lot,
Vinny
Thanks a lot,
Vinny
tintin
- processor: Ryzen R5 3600X
mh
looks like i should really write a detailed documentation of that plugin
you already can enter several texts... one text - with each different settings of course - on each layer. just add a layer and enabling zText gives you another text... that's all.
note: you may add a layer without adding a region on it. if you add a region the text may only be visible in the added region.
br,
tintin
br,
tintin
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Yeah, but this is useless for a preset in the queue ;-(tintin wrote:you already can enter several texts... one text - with each different settings of course - on each layer.
cheers
afx
tintin
yes and no....afx wrote:Yeah, but this is useless for a preset in the queue ;-(
you can tweak the preset.xmp a bit. through changing the lines
Code: Select all
blay:layerId="0"
blay:layerPos="0"
BUT: this only works if the number you put in is the next layer to be added or a layer that is already available - so using "1" should work in any way but might overwirte existing settings of layer 1. if you put "2" in the xmp, but layer "1" is not available when clicking the preset ASP will hang.
br,
tintin
afx
- System_Drive: N/A
No really practical for a generic watermark queue me thinkstintin wrote:BUT: this only works if the number you put in is the next layer to be added or a layer that is already available - so using "1" should work in any way but might overwirte existing settings of layer 1. if you put "2" in the xmp, but layer "1" is not available when clicking the preset ASP will hang.
cheers
afx
hannes_hab
- System_Drive: Z
- motherboard: ASUSTeK P8H77-I
- processor: Intel Core i7 3770K 3.5 GHz x 8
- ram: 16 GB
- Video Card: AMD Radeon R7 200 Series
- sound_card: Radeon HD 7700 7800 Sapphire
- Hard_Drive_Capacity: 2x250GbSSD
- Monitor/Display Make & Model: LG IPS 21:9 UltraWide 34UM95-P 3440x1440
- Corel programs: AfterShotPro 1, 2, (3)
thank you for that hint - did not know that,
if you know it and do this as the first (layer-maybe as a reservation text1 and text2 without text) editing it is really helpful
regards Hannes
austria
Nikon D7000 + D70, Nikon P6000, Nikon P330 (use P7800) PanasonicTZ100, Vuescan
bibble 4, bibble 5, ASP mostly on Ubuntu 14.04 ( sometimes Suse Linux 11.4 or WIN10)
austria
tintin
why not?afx wrote:No really practical for a generic watermark queue me thinks
you might adapt your personel workflow slightly through using layer1 always as your watermark layer.... any other adaptation might follow on layer2+
afx
- System_Drive: N/A
What about my old images?tintin wrote:why not?afx wrote:No really practical for a generic watermark queue me thinks
Relying on a specific layer management sounds like a recipe for trouble to me.
cheers
afx
tintin
i had expected that you either have images that are already processed - so all settings are already done - or you have images that are not processed, yet - for those the workflow might be adapted from now onafx wrote:What about my old images?
tintin
see here http://forum.corel.com/EN/viewtopic.php?f=96&t=45441Vinny wrote:Could you give us some update with zFrame and zSoft please. Are you working on it for the new beta?
here http://forum.corel.com/EN/viewtopic.php?f=96&t=45746
and here http://forum.corel.com/EN/viewtopic.php?f=96&t=48453
afx
- System_Drive: N/A
There is a difference between base processing and output processing.tintin wrote:i had expected that you either have images that are already processed - so all settings are already done - or you have images that are not processed, yet - for those the workflow might be adapted from now onafx wrote:What about my old images?
I might want to put images online years after I have processed them for the visual appearance. Then I would add the watermark in the queue just for that instance.
cheers
afx
hannes_hab
- System_Drive: Z
- ram: 16 GB
one question to layers - its possible to create a layer with a preset - and several layers with preset layer1 and preset layer2 and so on ...
but how to create a (one) preset with frame and text on layer 0 and text on two additional layers?
Is this possible with ASP?
regards Hannes
austria
austria
tintin
yes, it is! (i just tested that)
you have to manipulate your corresponding preset xmp-file manually.
in the xmp file is a section starting with and ending with the following tags
just copy this section and change the layer settings from 0 to 1 and/or to 2, etc.
the individual bopt: settings for the different sections might then either be edited in a text editor, too, or copied from another previously prepeared preset.
so it should look like...
br,
tintin
Code: Select all
<rdf:li>
</rdf:li>
Code: Select all
<x:xmpmeta xmlns:x="adobe:ns:meta/" x:xmptk="XMP Core 4.4.0">
<rdf:RDF xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#">
<rdf:Description rdf:about=""
xmlns:bib="http://www.bibblelabs.com/BibbleToplevel/5.0/"
xmlns:bset="http://www.bibblelabs.com/BibbleSettings/5.0/"
xmlns:blay="http://www.bibblelabs.com/BibbleLayers/5.0/"
xmlns:bopt="http://www.bibblelabs.com/BibbleOpt/5.0/">
<bib:settings>
<rdf:Description
bset:settingsVersion="66"
bset:respectsTransform="True"
bset:curLayer="0">
<bset:layers>
<rdf:Seq>
<rdf:li>
<rdf:Description
blay:layerId="1"
blay:layerPos="1"
blay:name="myLayer1"
blay:enabled="True">
<blay:options
bopt:... />
</rdf:Description>
</rdf:li>
<rdf:li>
<rdf:Description
blay:layerId="2"
blay:layerPos="2"
blay:name="myLayer2"
<blay:options
bopt:.../>
</rdf:Description>
</rdf:li>
</rdf:Seq>
</bset:layers>
</rdf:Description>
</bib:settings>
</rdf:Description>
</rdf:RDF>
</x:xmpmeta>tintin
hannes_hab
- System_Drive: Z
- ram: 16 GB
thank you!
I will try it
I will try it
regards Hannes
austria
austria
hannes_hab
- System_Drive: Z
- ram: 16 GB
copied your example "it should look like", but it did not work here - maybe this is not a working .xmp ? and / or I did something wrong ( ASP version 1.0.1.10)
regards Hannes
austria
austria
