zText on beta 1.1.028
AfterShot Pro Plugins
EOS
operating_system: Linux
System_Drive: N/A
motherboard: Gigabyte
processor: Core i7-3930K
ram: 12GB
Video Card: Nvidia
Monitor/Display Make & Model: 2x Samsung SyncMaster 21 inch
Post by EOS »
Tintin, maby to early :wink:
but zText stops working in the beta 1.1.0.28
or at least in export no text on picture , but seeing in the picture before export.
mikmak
Re: zText on beta 1.1.028
Post by mikmak »
Same problem with zFrame and zShadow. You see it ok on the screen, but nothing in outputfile.
Regards
Per
tintin
processor: Ryzen R5 3600X
Post by tintin »
mh,
you're right... additionally zSoften does also not work.
only zChannelMixer and zPerspector do work of my plugins.
i'll now try to dig in that more deeply... :?
br,
tintin
my plugins on the official plugins homepage
If you find my plugins helpful, please make a donation to support further developments - just click here, thank you!
tintin
Post by tintin »
hi,
looks like corel changed somthing in the image pipeline.
there is now a pipe stage called "WorkingToMonitor" placed before my plugins (you may check this through looking in th AfterShotPro.log file). this pipe stage had been behind the plugins in the former versions. so i think i will release some updates soon that adapt the pipe stage placements of the affected plugins ( 'soon' means that i will start highly probably thursday with the first plugin, no time tomorrow).
thx to be patient,
br,
tintin
EOS
System_Drive: N/A
ram: 12GB
Video Card: Nvidia
Post by EOS »
Thx Tintin :D
tintin
Post by tintin »
hi,
i just updated zShadow as the first plugin. with this update zFrame and zSoften should already work again. this comes from the fact that both plugin zFrame and zSoften refer on zShadow if it present. only if zShadow is not installed zFrame and zSoften will not work, yet.
so if you have zFrame or zSoften but not zShadow you could either wait some more days until i updated them as well or you install zShadow in the meanwhile ;-)
here is the link to the latest version of zShadow...
http://aftershotpro.com/plugins/?plug=zshadow
since zText is not working yet just with the update of zShadow, it will be the next update.
br,
tintin
tintin
Post by tintin »
ferdinand-paris
motherboard: GA-X58A-UD3R
processor: 3.20 gigahertz Intel Core i7 960
ram: 4Gb
Video Card: NVIDIA GeForce 7300 GS
sound_card: Realtek High Definition Audio on-board
Hard_Drive_Capacity: 2500 Gb
Monitor/Display Make & Model: Eizo CG222W
Post by ferdinand-paris »
TinTin
Have you thought about providing support for asPluginManager as part of these updates? It's not much code and fairly simple.
F_P
EOS
System_Drive: N/A
ram: 12GB
Video Card: Nvidia
Post by EOS »
Thx for the update of zText (update v2.3.0)
it works in beta 1.1.0.30 but is it true is doesn't work anymore in the stable version 1.0.1?
tintin
Post by tintin »
ferdinand-paris wrote:Have you thought about providing support for asPluginManager as part of these updates? It's not much code and fairly simple.
i did - and i think i will implement it with the next updates. now i just wanted to roll out the fix for the pipeline issue as quick as possible.
br,
tintin
tintin
Post by tintin »
EOS wrote:Thx for the update of zText (update v2.3.0)
mh,
isn't the 1.1.0.30 the most stable version, now? ;-)
jokes aside... you are probably right. do you still have version 2.2.0 of zText for your 1.0.1 version of asp?
i'll fix that as a new version of zText v2.3.1 very soon - then it should work with both.
br,
tintin
EOS
System_Drive: N/A
ram: 12GB
Video Card: Nvidia
Post by EOS »
np still have 2.2.0 i just noticed ;-)
tintin
Post by tintin »
Vinny
Post by Vinny »
Hi TinTin,
Could you give us some update with zFrame and zSoft please. Are you working on it for the new beta?
Thanks,
Vinny
tintin
Post by tintin »
yes, i"m about.
the updates are nearly finalized.
but you need to be patient till coming weekend.
br,
tintin
