"Auto chapter" does'nt place chapers in the main p
KevinD
Post by KevinD »
I recently purchased Hauppauge WinTv-PVR-150, and it was bundled with Ulead DVD MovieFactory 3 SE. The video capure works great , but when I try to break it up into chapters with the "Add/Edit Chapter" button no chapters are created. I press the "Auto" button and the "Auto Add Chapters" dialog window pops up. I enter the minuts at the "Add chapters at fixed inervals:" spot. Hit the "OK" button and a percentage of completion bar pops up. When that finishes the "Add/Edit Chapter" window has the chapters on the right side, with total number of chapters up top. Hit the "OK" button, the "Add/Edit Chapter" window disapears, the hourglass cursor pops up for a couple of seconds, but none of the chapters show up at the bottom of the main window.
Thank you for your help.
Kevin
ploggy
Post by ploggy »
these chapters will only be visible in the menu. The clips below the main window "Add/Edit Media" represents the titles in your DVD, which, can contain chapters.
KevinD
Post by KevinD »
I had gone in the "Menu" window before and still only seen the one chapter,
but I checked "Create chapter menu" and there they are.
Thanks again.
ploggy
Post by ploggy »
there is a listbox there for the current displayed menu. usually the default view there is the main menu. You have to select the submenu in that list box for you to view/edit them.
