I'm neither able to print using one of the standard print queues nor defining a new one nor modifying one of the standard queues. ASP hangs and I have to stop the process e.g. using the task manager. It doesn't matter if I do it from the file manager or the library. Any ideas how to fix that?
btw. there is no log file in my user directory ~/AppsData/Local/Corel/AfterShot Pro
Thanks in advance,
Stephan
p.s.
my ASP version is 1.0.1.10
ASP crashes when printing, modifiying or adding a print queu
stephanma
- motherboard: Dell Inc. 066NDV A00
- processor: 3.10 gigahertz Intel Core i7-3770S
- ram: 6GB
- Video Card: NVIDIA GeForce GT 640M
- Hard_Drive_Capacity: 2TB
- Monitor/Display Make & Model: Nissei Sangyo XPS One 2710
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Re: ASP crashes when printing, modifiying or adding a print
Where does it hang?
What printer?
Can you print to a PDF?
And if you have no log file, it sounds like something is seriously hosed and you don't have permissions to write to your user directory.
cheers
afx
What printer?
cheers
afx
stephanma
- ram: 6GB
It hangs with any print queue provided by corel (even with pdf). After starting the job it takes about 15s then ASP does not respond any more. The same with defining new queues or modifying the properties of the exisiting queues - after some seconds ASP does not respond. I had been waiting 5 to 10 minutes before I end the ASP process. It should not take that long ... When I kill and restart ASP after trying to create a new print queue, ASP shows a new queue called "new ..." (I'm on a machine with german locals and I don't now the exact english wording for that).
I'll check the permissions on my directory when I am on my machine at home, but I could install plugins and preferences.
regards
regards
stephanma
- ram: 6GB
after booting my machine this evening everything works fine. I can print, add queues, modify queus. And there is a living log file
After many years working with linux I forgot about the oldest windows repair mechanism - rebooting
Thank you for your attention and help!!
Try to update to the latest version when you have issues, I usually do this first and it often fixes thingsstephanma wrote:after booting my machine this evening everything works fine. I can print, add queues, modify queus. And there is a living log file![]()
After many years working with linux I forgot about the oldest windows repair mechanism - rebooting![]()
ferdinand-paris
- motherboard: GA-X58A-UD3R
- processor: 3.20 gigahertz Intel Core i7 960
- ram: 4Gb
- Video Card: NVIDIA GeForce 7300 GS
- sound_card: Realtek High Definition Audio on-board
- Hard_Drive_Capacity: 2500 Gb
- Monitor/Display Make & Model: Eizo CG222W
Like removing Noise Ninja?jhenry wrote:Try to update to the latest version when you have issues, I usually do this first and it often fixes things
