Hilight/Clipping Warning Does Not Work
Bugs & Suggestions
dori
operating_system: Linux
System_Drive: N/A
Post by dori »
The highlights clipping warning does not work. This is on RAW files. I can bring the exposure setting all the way to the right, and no clipping shows.
This bug was first introduced after Bibble 5.2.2, and I see that it persists in Corel AfterShot Pro.
It's a very useful tool, please fix this bug! I upgraded to Corel AfterShot Pro, but I'm stucking using Bibble just due to this bug.
Thanks!
P.S. I'm using the AMD64 Debian package under Ubuntu.
afx
System_Drive: N/A
Video Card: FirePro 4900
Re: Hilight/Clipping Warning Does Not Work
Post by afx »
Hmm, works for me.
So what is your threshold value?
cheers
afx
dori
System_Drive: N/A
Post by dori »
The threshold was the default 254. I tried setting it to lower and it didn't work.
WilsonC
Monitor/Display Make & Model: Samsung SA300
Post by WilsonC »
Do you have Curves enabled? If so, turn it off and see if you get the warning. In curves you can bring down the white point ever so slightly so that the highlight warning does not go off.....even if you max out the exposure and contrast controls.
-Christopher
dori
System_Drive: N/A
Post by dori »
The curves were off, but I just realized that the tool works for RAW files from Canon (350D, 40D, 5DMII), but does not work for raw files from my Panasonic DMC-GF3. At least for the moment, I think the bug may be confined to this specific RAW format.
Trucks
System_Drive: N/A
motherboard: 64bit
processor: quad
ram: 3GB
Video Card: Nvidia
sound_card: onboard
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: Eizo S2243 W
Post by Trucks »
i dont see your cam in this list: http://www.corel.com/corel/product/inde ... de=en#tab4 only GF1 and GF2. Maybe there comes the Problem?
Regards
Test123
dori
System_Drive: N/A
Post by dori »
OK, I was mistaken. The issue isn't just Panasonic GF3 specific. It just happened to me on a Canon 5D MII raw file. I'll upload a screenshot. Notice how I've enabled the clip warning and pushed the exposure to +3, and still no clip warning shows up.
It's possible the perfectly clear option is messing it up. If I turn it off it seems to work.
clip warning doesn't work.
