Video Jitter/Shaking
ckuhn87
After transfering my video to the computer, the replay shakes when the camera moves. When the scene is still there is no problem. Problem only occurs with captured video. Replay with actual tape through the camcorder is normal.
Bandit
Shakes
You did not give any specs about your system, especially your capture card. I had the same problem with captured video and solved it by changing the capture from "High" to "Medium" capture settings. I personally do not see any difference in the end results. This may or may not be acceptable for your needs and may not be the only cure. I suggest trying it - if only to see if your card can handle the data rate. Anyway, here is one possible solution. Hopefully someone with better knowledge will answer and we will both get better results. Good luck
Bandit
Bandit
videomartin
