How can i use icc profile which i get with ColorChecker Passport?
And your ColorChecker Passport experience with ASP?
Thank you
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Re: ColorChecker Passport
Not sure whether the colorchecker passport generated profile works.
But you can shoot the chart, switch to linear bump up the exposure by about 2 stops and generate a linear tiff for ArgyllCMS to be analyzed which then can be used by AS.
It is a bit tricky with such a small target, one with more patches would be better.
cheers
afx
cheers
afx
Funny that I contacted a French expert on color management this week to ask the exact same question.
So, I can confirm that Xrite software can't generate calibration file that can be used in ASP. Not sure if it's allowed to provide any external link on this forum. If not, then just delete what is coming:
This French expert does provide calibration that is usable in ASP (in the form of ICC profiles). It is in French, here: http://www.cmp-color.fr/digital%20target.html
