I can set the white balance well by:
* clicking white in ASP.
* Taking a raw photo in the camera using a wb lens cap, and then using that photo as a reference for my 5d iii's custom wb.
Is there a way to load my raw wb photo file into ASP and then use that to set the wb of other pictures?
Thanks,
Andy
Setting the White Balance from another image?
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Re: Setting the White Balance from another image?
Copy&Paste, Selective Copy, a Preset or a Copy Set for White Balance can all be used to copy WB from one image to another.
One caveat though. When copying a WB "As Shot", the marker for "As Shot" will be copied, not the actual values. So before copying it, just switch to custom and then copy so that the actual values are used.
cheers
afx
cheers
afx
G0bble
- motherboard: 880GM gigabyte
- processor: Athlon X4 3.6Ghz
- ram: 12GB
- Video Card: onboard
- sound_card: onboard
- Monitor/Display Make & Model: Dell U2414H
- Corel programs: VSx10.5 Aftershot Pro 2/3
I could not select only WB to copy though - it copies all other settings too. I dont think Selective copy lets you fine grained selection.afx wrote:Copy&Paste, Selective Copy, a Preset or a Copy Set for White Balance can all be used to copy WB from one image to another.
cheers
afx
-G0bble
afx
- System_Drive: N/A
Athen you are doing something wrong....
look at the advanced tab...
cheers
afx
cheers
afx
