catalog: opening related file in file-sytem mode
hannes_hab
operating_system: Linux
System_Drive: Z
motherboard: ASUSTeK P8H77-I
processor: Intel Core i7 3770K 3.5 GHz x 8
ram: 16 GB
Video Card: AMD Radeon R7 200 Series
sound_card: Radeon HD 7700 7800 Sapphire
Hard_Drive_Capacity: 2x250GbSSD
Monitor/Display Make & Model: LG IPS 21:9 UltraWide 34UM95-P 3440x1440
Corel programs: AfterShotPro 1, 2, (3)
Post by hannes_hab »
is it possible to open a selected file from within the catalog in file system mode?
are to use another way:
is it possible to import a file from within one catalog to a new or existing cataolg?
regards Hannes
austria
Nikon D7000 + D70, Nikon P6000, Nikon P330 (use P7800) PanasonicTZ100, Vuescan
bibble 4, bibble 5, ASP mostly on Ubuntu 14.04 ( sometimes Suse Linux 11.4 or WIN10)
afx
System_Drive: N/A
Video Card: FirePro 4900
Re: catalog: opening related file in file-sytem mode
Post by afx »
Why don't you try?
Probably faster than posting ;-)
I just set up a batch queue with a copy job and used that. Works.
cheers
afx
hannes_hab
System_Drive: Z
ram: 16 GB
Thanks you for your reply,
but I don't want to make a copy of the file - I just want to import the same file to a new catalog - without searching the file in file system mode and then import - but maybe I don't understand what you are doing ...
I have the possibility to use version - show folder of the original file - but only in nautilus (in my case) - not show folder of the original file in ASP file system mode - then re-import would be a bit faster - but maybe you know the working trick
regards Hannes
austria
ogrizzo
operating_system: Mac
System_Drive: Q
processor: 2.8 Ghz Intel Core i7
ram: 8 GB
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: Integrated Apple iMac 27"
Post by ogrizzo »
hannes_hab wrote:Thanks you for your reply,
If I understand you correctly, you want to (re)import an image, but if you use the file system pane then ASP will create a preview for every image in the same directory, which could take quite a long while.
The easiest way out is to unselect Preferences|Import & Cache|Create Previews during Importing and File System Browsing : ASP won't create any preview, it'll just load the embedded one.
afx
System_Drive: N/A
Post by afx »
Ooops, sorry, I misunderstood.
Don't think it is currently possible to do it the way you want it.
cheers
afx
