HI, I've used "this code" since Bibble 4.
ASP has a really annoying 'bug' that seems to have returned from B5, although I had a workaround then:
I almost always use a custom crop. I can't immediately select it from the dropdown - clicking on the option DOESN'T select it the first time. You have to try twice. This was fixed in B5 for a while and now seems broken again.
Secondly, There was a way of setting it as my preference in the config. files, thus avoiding the need to select it each time. In ASP, I can't find the file in which this is stored. Can this still be done, and if so, could someone point me in the right direction, please?
Many thanks,
Simonm.
Setting crop defaults
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Re: Setting crop defaults
No need to muck about with files (they would be n the defaults directory of your user folder).simonm wrote:Secondly, There was a way of setting it as my preference in the config. files, thus avoiding the need to select it each time. In ASP, I can't find the file in which this is stored. Can this still be done, and if so, could someone point me in the right direction, please?
Just like in B5, save the custom setting as part of your image defaults.
cheers
afx
