Trim Video And Be Able To Reduce The Data Rate Only
oka
- motherboard: HP h8-1100z
- processor: AMD FX-6100 Six-Core Processor 3.30 GHz
- ram: 6 GB
- Video Card: AMD Radeon 6700 PCIE 1GB GDDR5
- Hard_Drive_Capacity: 1.1TB Free
- Monitor/Display Make & Model: Gateway LP1925 Monitors - Two
- Corel programs: VideoStudio X8
Re: Trim Video And Be Able To Reduce The Data Rate Only
Just curious. I believe it is not possible to edit videos, save them as projects and then batch render (create video files) with a template to respective files? Just checking!
File -- Batch Convert not only allows you to add video files but also accepts VSP Project Files.
You have to set the Convert settings via Options manually each time you use the process.
There is no way to select a pre-defined template, much similar to using the Share -- Create Video File -- Custom option.
