newblue titlerEX
Kazan
motherboard: 82F2A01
processor: Intel Core i5-7400CPU 3.00GHz
ram: 12Go
Video Card: NVIDIA GeForce GtX 1050 [Display adapter]
Hard_Drive_Capacity: 1387 Go
Monitor/Display Make & Model: BENQ
Corel programs: vdeostudio
newblue titlerEX
Post by Kazan »
I tried to use this plugin without success. I can load the plug in on my video clip, thru the option I gain access to the titler program, I can manipulate text etc..My problem start when I want to load the text on the clip. 1- How do you load the text to the clip? Clicking OK or what? When I click Ok the text appears in the X5 window but my clip does not show up. To reuse Titler I have to restart X5. What do I do wrong?
Re: newblue titlerEX
I do not use titlerEX but just gave it a run without problems
This is what i did........
Drag a video clip to the timeline, one of the library samples, i used the countdown timer
Drag the filter over the clip.
Double click the clip to open the "options" panel
Click Customise filter--opens the NewBlue Titler panel
Right click timeline to select "edit text"
I did not apply any further Styles, simply hit OK
The panel closed, the text showed on the preview screen.
If I were to add Styles the text may be hidden till i play the clip, depending on the effects I add.
Using the Styles, Transitions and Effects may take a while to learn???????????
Kazan
ram: 12Go
Post by Kazan »
I followed the steps you described. Unfortunetly when I hit OK, the text appears in the X5 window with a black background. I select project and I run the clip. The text remains on the screen but the clip disapeared i.e it runs on a black background.
